Question about Cisco Aironet 1131AG 802.11a, 802.11g/b (746320933474) Wireless Access Point
Cicso 1131ag Drops off
We are accessing the Cisco 1131ag using handheld devices (Dell) They keep dropping off. We have to unplug the access point and reset it to gain access again. Is there a configuration problem with the 1131ag that makes this more stable? We are using seven of these devices in several different buildings. One is mounted in a plywood observation booth in a gym; pointing through a plexiglass window. One is mounted behind a set of bleachers in a gym. One is mounted on a cement block wall in a gym. The rest are mounted in conference rooms.
  • 30 Answers
Sounds like authentication/encryption connectivity issues. Post your config and ill check.
Posted on May 12, 2009
    Problem Solver:
  • 5 Answers
Only time i've seen drop-offs from windows devices was on PEAP authenticated windows clients - needed a windows hot-fix for PEAP authentication, which is now included in XP SP3. If that's the problem, u can get ur fix from MS.
Posted on Jun 19, 2008
Meru
Posted on Mar 06, 2008
    Problem Solver:
  • 4 Answers
How are attached / verified by the LAN? Do you have a RADIUS server for the certificates?
Posted on Nov 18, 2006
Reset cisco airnet 1130ag
There are 2 ways to reset the access point.
Using the MODE Button
Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
1. blank.gifOpen the access point cover
2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. blank.gifEnter the username Cisco in the User Name field.
4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. blank.gifClick System Software. The System Software screen appears.
6. blank.gifClick System Configuration. The System Configuration screen appears.
7. blank.gifClick the Reset to Defaults button.
Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
8. blank.gifAfter the access point reboots, you must reconfigure it.
Aug 13, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Default username & password after hard reset
Username:[none]
Password:Cisco or
:root
:Cisco or
:Cisco
:Cisco
Try from above 3 then you can access cisco router.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 01, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Can I hook a 1131ag LWAP directly to a 7941g?
If the 7941g is the cisco cp-7941g ip phone then no you can not since the ip phone only has ethernet connections and the airap1131agak has only wireless connections on it as it is a wireless access point, so you will need a wireless router or something similar to get the wireless to ethernet cable.
Oct 29, 2009 | Cisco Aironet 1131AG (AIRAP1131AGAK)...
Radio0 and radio1 "not installed" problem on Cisco 1131AG
check that you have enough power on the PoE to power up both radios. Switch one off for clarity and see if 1 powers up. Also check the log of the AP and the PoE switch as it will report the power related issue if it is a pre- PoE approved switch
Mar 12, 2009 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Can't get email when connected to WiFi network
Your pop account settings might have to be changed.
Apr 10, 2017 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Ip address for clients using autonomous cisco 1130ag witout dchp
the cisco1130ag will provide ip addresses and serve as a DHCP server for your laptops...
You still need an IP address for your 1130ag so either your ISP provides you a static ip that you can put in the 1130 or if your ISP provides dhcp then you should be able to plug and play with your 1130ag
Jan 15, 2009 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Wireless power problem
After researching Cisco site. And testing. I suggested the coutomer log on to the device and adjust settings. It turns out the unit when using a power injector goes into a Power Managment mode. The unit goes to half power and can cause problems.
Thanks for the help.
Jun 10, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Jan 17, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Erasing the flash....
Toast...looks like you killed your entire IOS installation...it will have to be reloaded to the flash...
Aug 21, 2007 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Cisco Aironet 1131AG 802.11a, 802.11g/b (746320933474) Wireless Access Point Logo
541 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
