Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Blue aura at bottom of screen
There is a blue aura of light that has appeared at the bottom of my screen. It has been starting to spread over the last couple days and is now about 1.5 feet long across the bottom of the screen. I thought it might be a magnetic problem but all the electronics near the tv have been there for the last five months. I moved everything away just in case and it still hasn't changed anything. Any ideas?
  • Anonymous Nov 14, 2008
    same problem here only on the top of the screen
  • rvstults Dec 09, 2008
    i have the same problem with my 50v500 only in the middle of the screen from top to bottom. problem seems to get worse as tv warms up
    New Friend:
  • 21 Answers
Check 2 things.
First, make sure the lenses, mirrors, and back of screen are spotless. Second, look into the CRT's when the set is running. There is a real good chance cooling fluid leaked out or got cloudy. It's supposed to be a clear oily fluid (a combo of glycerine, water, sometimes methyl alcohol and preservatives) and will be around the tube and chassis if leaking. Rebuilding the assembly is possible (Magnavox had the same problem, as they were a Hitachi chassis), but the CRT is usually damaged. If I have to rebuild them, all 3 are done in one shot - new fluid, seals, filler spout.
Besides that, the tubes are cheap and lose their sharpness with age (gets gassy). Had real problems with that and the only correct solution is to replace all 3 tubes. You could cheap out with one tube, but setting the color balance (grey scale) is often difficult if not impossible.
Good luck,
Mark
Posted on Nov 15, 2008
To the much of my dissmay , my neighbor gave me his 50v500 hitachi tv. and it has the faint dreaded cntr blue aura syndrome. as I am quite aware of this light engine issuses and wonder if I can repair or...
Filter warping due to over heating.
The only repair for any of these symptoms is replacing the Engine Assembly.
Prevention:
To prevent the overheating caused by clogging of the bottom filter, upgrade to the new style bottom filter. Upgrade to New Style bottom Filter
Jan 22, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
My screen has a blue cloud that started in the bottom left corner and has now spread over most of the screen...is it the Lamp?.and now the TV will only stay on for a few mins. and the lamp fan is...
THE LAMP CAN ONLY AFFECT BRIGHTNESS NOT ANYTHING WITH VIDEO DISTORTION. THE BLUE DISTORTION WILL BE A OPTICAL ENGINE DEFECT AND MOST LIKELY NON-ECONOMICAL TO REPAIR.
Dec 16, 2010 | LG RU-60SZ30 60" Rear Projection...
Screen on tv is turning blue through the center
you have a lcd plate that is warped in the light engine and it will have to be repalced to correct this problem
you might contact hitachi and see if there still offering assistance or will provide a light engine you may have to pay labor if it still is on going but thats better then footing the whole bill
Oct 24, 2009 | Hitachi 51F500 51" Rear Projection...
I have a Sony Grand Wega KF-E42A10 and a blue aura has appeared at the bottom centre of the screen. I recently changed the bulb, but it was working fine for the last 2 months or so, since I changed the...
you have a light engine problem its a warped blue lcd plate
it will require a light engine change out ou might see if you have your reciept and get your model and serial and call sony and see if there is still assistance for this problem
Oct 23, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Near the bottom edge of the screen on my Wega KF-50WE 610 has appeared a ''blue haze'' that appears after the TV has warmed up. It started a few days ago as ''fuzzy blue dots'' about the size of silver...
This was caused by a defect in the optical block of the TV. It will only get worse with time and the only way to fix it is to replace the whole optical block which is very expensive (over $1000 usually) and time consuming (you need to take the whole TV apart). However, since it was a defect, there was a class action lawsuit that caused Sony to extended the warranties for certain models on the optical block for parts and labor. Call Sony to see if your model was one of the ones they extended the warranty for.
Oct 04, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Blue haze/cloud in center of screen, slowly spreading
how to fix my problem Blue haze/cloud in center of screen, slowly spreading .but last time my lamp broken I order by my self and fixed now I have the blue color in my screen please let me know what is the problem may be I need to replaced same parts please let me know how to fix thank you
May 13, 2009 | Hitachi 55VS69 55" Projection HDTV
Rear projection screen 152cm lg going yellow
I am guessing that this is an LCD projection set, Please post the make and model so I can confirm. In the mean time, if it is an LCD, there are 2 possiblities.
1) The lamp may require changing. Sometimes the inner surface deteriorates because of the heat.
2) The "light engine" requires replacement as the heat and light have started to burn the LCD surface. This burning starts to show up as a yellowing usually onm one side first and spreading to the other side.
Dan
May 07, 2008 | Computers & Internet
Screen now showing blue line at bottom
Sounds like, you have a bad optical block. Part can cost $550 to $800 + labor
Mar 28, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
