Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Connecting my Seagate 500GB USB drive reboots PC continuously.
When I connect my Seagate 500GB USB hard drive to my desktop PC or my notebook (both running XP Home), the computers reboot. If the computer is on when I connect it, the computer begins to reboot over and over again. If I connect the Seagate to the computer and then turn it on, the computer still reboots over and over again. I can not boot up either of my computers when the Seagate is attached to it, so I can not scan the Seagate for malware or recover any of the data. What would cause the computer to loop in a reboot process when the Seagate is attached to it? Any help would be appreciated. Thank you.
  • mshihabudin Dec 29, 2008
    I have a Seagate FreeAgent Desk 1 TB Drive. My comp simply refuses to boot when the Hard Disk is connected! Everything works when its not.. Confused and crestfallen:(
  • 29 Answers
Update the firmware from seagate official,sir,any problem u can contact with me,thanks honglake@gmail.com
Posted on Apr 28, 2009
How to connect
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall....
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 500GB FREEAGENT DESKTOP 7200RPM EXTERNAL USB 20 HARD DRIVE 16MB it just stoped working in the middle of the movie, complete blackout, tryed conect to another PC nothing came up, what it could be...
Try this:
1. Turn off the power supply to the hard drive.
2. Turn off your PC/laptop.
3. Connect the hard drive to the PC/laptop.
4. Turn on both devices.
It worked with mine.
You could also try installing Seagate Manager which can check for errors on the drive.
Jun 10, 2011 | Seagate 500GB FREEAGENT DESKTOP 7200RPM...
Hi i have got seagate Go 500gb when i connected to my computer it say that insert a disk into your Usb .i would like to know how can i fix it
Can you give any more information? What kind of PC? Age of PC? How old is the external drive? is the drive new? Esata is different then USB. Make sure you are connecting to an eSATA port on the computer. Newer laptops usually have a shared eSATA and USB port.
Feb 10, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Seagate FreeAgent Go 500 GB, stopped working in the middle of copying some of its data into my PC. Now instead of the constant light-up when connecting to the pc, it blinks continually. And the hard...
First i would remove and reinstall drivers for this device,next try device on another system if it works ok on another system drive ok if not drive has failed.Good luck!!!
Jan 08, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My seagate external hdd 500gb is not working and is not detected and regonised in any pc..
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 07, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi I Have a 500GB External desktop dtive and can not get it to work, i have try it with two computers and it do not pick it up the Green light on the box is just flashing and not on all the time regards ...
Try connecting it to a different USB port on your computer.
Try connecting it to a different computer.
If the problem persists, either:
* the USB cable is damaged,
* inside the enclosure, the disk-drive is not functioning
(although the lamp indicates that it is getting electrical power)
* inside the enclosure, the USB-to-disk-drive adapter has failed.
If the warranty is still valid, Seagate will replace it, at no cost to you.
Or, open the enclosure, and remove the disk-drive, and temporarily connect it as a "slave" disk-drive in a desktop computer, to see if it is working at all.
Or, buy a new, compatible, disk-drive, and mount it into the enclosure, to make a "new" external disk-drive.
Oct 29, 2010 | Seagate 500GB Desktop External Drive ...
Cannot access / view hard drive from my PC.
Try connecting it to a USB port on a different computer.
If the problem continues, then one of the two major components inside the enclosure:
* disk-drive
* USB-to-disk-drive adapter
have failed.
Open the enclosure, and remove the disk-drive, and connect it as a "slave" disk-drive in a desktop computer, to see if the disk-drive, by itself, still is accessible. If not, then you could buy a new disk-drive, and "transplant" it into the enclosure, to "resurrect" your external enclosure.
Is the disk-drive still under warranty? If so, contact Seagate, and exercise the warranty, to get a replacement.
Oct 12, 2010 | Seagate 160GB 3.5" External USB Drive 160...
My desktop crashed. I lost everything on it. I thought I downloaded some informatin on my Seagate Externa harddrive, however, I am having problems connecting to other computers to see if any information is...
External hard drives are plug and play, the drivers are build into windows.
IF the hard drive was connected when your computed crashed, and the hard drive was in use, it may have damaged it.
If it does not automatically connect to other PC's looks like it has been damaged
Aug 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a 1tb seagate desktop, the light doesn't turn on and it makes a clicking sound and when plugged in the computer nothing happens
Try first connecting the drive to a different USB port on your computer and check if it will be working fine, but if still not working better try connecting it to a different computer ad check if same result. If still not working try using a different USB cable and see if that will fix the problem but if still not working the drive is already bad and better try to check it with the manufacturer of your drive and have them recover your data inside it.
Apr 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
281 people viewed this question
Top Seagate Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Steve
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
