Question about HP Photosmart D7160 InkJet Printer
Ink System Failure
Error: 0xc18a0501
Tried power cycling, but no luck. Outisde of warranty. Does anyone know what this means?
Thanks I GET THE Error 0xc180501 . i have put all new ink in. please help what is the problem.
  • 4,041 Answers
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (Ink System Failure - c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Posted on Jan 25, 2010
  • Kricketbs Apr 10, 2011
    3.Wait for the 'Insert Cartridges ' message to display on the control panel.
    With the top open or closed to get the message?
Ink System Failure
Have you tried to remove and reseat the printer ink cartg.?
Feb 11, 2008 | HP Photosmart 3210 Printer
Hp deskjet c7280 giving a error 0xc180501 what to do?
I myself have not tried this, but apparently it came from HP.
HP Photosmart C5180 show ink system failure message
This was what I was told to do for my C5180. First they told me to do a power drain. This is done by pulling out the power cable and then holding the on/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it.
Have to say it looked like this whole process used up shed loads of ink, so by the time I had finished I needed to replace 3 cartridges!
Thanks,
Bhautesh.
Aug 21, 2010 | HP Photosmart C7280 Printer
Error:0xc18a0501 on HP Photosmart 3210
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 31, 2010 | HP Photosmart 3210 All-In-One InkJet...
Getting error 0xc19a0023 with HP Photosmart D5460 which is only a few weeks out of warranty. It happened suddenly in the middle of printing a colour page. I've tried resetting the hardware code (Print...
The official solution is to power off and reset the printer, as this is an ink system failure:
- power off the printer
- disconnect power cord
- wait 30 seconds
- reconnect power cord
- power on the printer.
Frankly this looks a bit like mumbo-jumbo to me, but it's worth a try.
Searching on the Internet finds out this other suggestion,
"...is being handled by the Level 2 techs at HP and all L1 agents have been instructed to transfer the call to the L2 techs. So give a call to HP Tech Support and they will take care of this one way or the other."
Oct 23, 2009 | HP Office Equipment & Supplies
HP 7280 All in one problem Ink System failure Error 0xc18a0501 I have tried shutting down even reset the system, but it still produces same error code.
1. Try to remove and reinstall the Ink Catridges. Be sure it is lock in place on the ink cartridge holder.
2. Turn off the Printer and unplug and replug the power adapter.
3. Uninstall and reinstall the printer driver.
Jun 16, 2009 | OKI C3400n Laser Printer
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Ink System Failure
did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. it will recalibrate and ask to replace almost all of the ink cartridges, however Unplugging the printer, while then pressing the help and ok buttons simultaneously plug it back in did fix it and I am able to print again. Thank you soo soo soo much.
Apr 18, 2008 | HP Photosmart C5180 All-In-One InkJet...
Electrolux Gallery Dishwasher Error Message AL3
It sounds like it could be a heater problem, I would check this first
Nov 26, 2007 | Dishwashers
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
HP Photosmart D7160 InkJet Printer Logo
313 people viewed this question
Ben Johnson
