Question about Panasonic PT-47WX42 47" Rear Projection Television
Double image on screen
Had this tv for 5 years now and it just started showwing double images on the screen. Could you tell me what this could be and is it something I can fix myself.
  • Panasonic Master
  • 3,459 Answers
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
double image on screen - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 30, 2010
Double image in samsung lcd tv
IF it is still under warranty, take it in to be replaced.
Aug 28, 2014 | Samsung Televison & Video
Seeing double
You need to replace the convergence board in your tv .
Also you have mentioned it is 5 years old so its time to replace it .
But it will not be cost effective one .
SAM ANDERSON
Sep 21, 2008 | JVC AV-48WP74 48" Rear Projection...
I've had my Toshiba 46RV530U less than 2 years,
Diana, did you ever find a solution? My Toshiba (same model) is about 2 years old and it started getting these 4 horizontal lines spaced pretty far apart and a double image at bottom. When I lightly tap the top of the TV, they went away. But now that is not working. Please let me know. Thanks.
Jeff
May 15, 2010 | Toshiba REGZA 46RV530U LCD TV
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Double image shows in red
it is quite fixable and usually in your home; it is called convergence--kp57wv500 uses two STK 392-560 convergence Ic chips; both and any bad fuses or resistors around them need to be replaced and the set adjusted after.
I fix a lot of these sets in my area---if you call a shop you will pay 300-400----a lot of independent people will do it for under 250 in your home--shop around--now is the slow time of the year for tv shops---you could buy both IC chips on ebay for less then 13 dollars plus shipping---this is a normal problem in all projection tv sets--the chips have a white grease on the back of them designed to transfer heat--after several years it drys out and one of them goes bad---repair should take about an hour or so in your home---you should ask yourself if 200-300 dollar repair is worth while, could you replace the set for this? If the chips are replaced and the set adjusted they should be good for 4 or 5 years at the least.
I do this here for free so if this has been helpful give me a vote here. If you have questions or need more help here is my email:
etower.766@netzero.net
Aug 19, 2009 | Sony KP-57WV700 57" Rear Projection HDTV
I am getting double images while watching TV;
There maybe some loose components on the circuit and that needs resoldering. Bring it to the repair shop to done.
Dec 02, 2008 | Zenith C27A24T 27" TV
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Blurry double image on the edge of the tv...
If you have tried to adjust the convergence on your TV within the menu feature then typically you do have a convergence problem. Check out this video to be sure...
Apr 16, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
