Back to:
Tags:
O2 Xda II Smartphone
REPLACED FULL SCREEN NOW ONLY WHITE SCREEN
posted by VLADIMPALER on Nov 09, 2006
i have a xda 3 i cracked the screen i replaced it with a new one, a full screen touch screen /lcd, now when i turn it on all i see is a white blank screen. it isnt in bootloader mode. when i sync it to the computer [mac] i can open the folders and see the inside of the xda.
ive connected the screen correctly, wheat do i have to do to make it work correctly?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 06, 2008
Not Rated (0)
Belize2004
Rank:Guru Guru
Rating: 89%, 61 votes
I suggest uninstall the LCD and reinstall it, sometimes that will fix the problem
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on REPLACED FULL SCREEN NOW ONLY WHITE SCREEN:
I don't want to Accept this solution
Solution #2
posted on Feb 05, 2008
Not Rated (0)
honey2509
Rank:Wiz Wiz
Rating: 81%, 84 votes
hi there
your phone is in bootloder mode....you need to format the phone and if required you can install the os again..
All the Best.
Thank You!
Can you Help with these PDAs problems?
when i was walking to the second floor i tried to turn my...
Why is it that when I delete files in my O2 PDA Smartphone...
camera and video not working
my pda o2 xda II this program error
I have an 02 xda 11 smartphone. I find my screen turns...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
