Question about Canon DR-6080 Path-Through Scanner
How to get rid of a black strip (1") on the leading edge of scanned documents?
We are getting a black strip on the leading edge of the 8.5 x 11 documents, and it cuts off the bottom of the image, unless we scan all documents as legal. Rollers have been changed, and glass cleaned.
  • Anonymous Mar 26, 2014
    When I one click scan to email the document is a bunch of jiberish
  • 490 Answers
You must be using Auto contrast/brightness. Change to manual, try one or two scans changing the brightness tab moving left or right and choose desire output quality. Remember the settings for that set of documents. The brightness will vary depending upon data (foreground) and noise (background). For a different set of docs you may need to adjust the settings slightly.
S. Mohan
Posted on Dec 02, 2007
Why are there black shades on the document?
the page is not against the glass,you need to close the lid tight
Jul 16, 2015 | Kodak I2600 Scanner
When I print documents from any computer hooked up to it or make copies, the edges are getting cut off.
Dear Lyris
pl. do the margin setting of the document as well as paper. The setting of scanning may be done up to 4mm leading edge and left edge up to 2.5mm.
Thanks.
Mar 30, 2015 | Canon imageRUNNER C2550 Color Copier
Kodak i660 black line on scanned document
The black lines are caused by either marks on the scanning strip or a fault with the scanner. If there are no marks on the scanning strip then there's nothing that can be done without sending it for repair. Details of the cleaning procedure are shown in the instruction manual.
Jul 19, 2012 | Kodak i660 Scanner
Canon DR-9080C Scanner all of a sudden all color documents scanned have a pink tint to them. I do not know how to get rid of the pink. Have been using the scanner for years. Also use Adobe as the...
Sounds like the shading compensation strips may be dirty and/or sticking. Otherwise the scan sensor is going out.
To check and clean the the shading compensation strips:
Open the feeder up all the way and hold down the red stop button.
...in about 5 seconds the upper and lower shading compensation strips will pop up.
They may be getting stuck and not popping out all the way (about 1/2")
Clean them up with a small brush and a lint free rag with alcohol.
If the shading sensor strips aren't popping out all the way, this will cause the problem you described, so clean them up and repeat this several times.
(They pop up during the document scanning process)
If they still aren't popping out after cleaning them up, then there may be a mechanical problem with the mechanism.
Hope this helps! You may need a tech.
I am in Dallas, Texas if you are local to me I can put an eye on it.
Sep 15, 2011 | Canon DR-9080C Path-Through Scanner
When using the automatic document feeder to print,scan, or fax, the finished page displays a thin line about 5-3/8" inches from the left edge of a 8.5x11 paper. When using the flatbed, no line is...
You need to change the mylar strip on the ADF and also you need to clean the narrow strip of glass that the scanner uses for ADF scans. The Mylar strip is found by opening the lid, as you do when you put a document on the glass. On the left side you will see a Mylar sheet that covers a white backing section. There is a latch on the front and back of the Mylar mount that allows it to drop down. There should be spare Mylars in an envelope tucked under right edge of the white backing strip for documents placed on the glass. Just be sure to orient the new strip the same as the old one. The mylar strips can sometimes be cleaned but usually it is better to replace it if you have spares.
Aug 09, 2011 | HP LaserJet 4345mfp Printer
How do you scan?
Open the Applications folder on the hard disk on which MP Navigator is installed, then open the Canon Utilities folder and double-click the navicon.gif MP Navigator 3.0 icon. MP Navigator opens.
2. Point to Scan/Import and click 'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select 'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly if you do not leave 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
  • When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
  • When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
Oct 26, 2010 | Canon MP610 Photo All-In-One Printer
Black line through the middle of the document
The thick line is either because of dust sticking to the glass or a module problem. Try different brightness settings and scan white paper. If the thickness varies and also the sides of the black strip are jaggered (step like) then it is dust on Glass. use isopropyl alcohol to clean, dont use solvents. If the teickness is same for all levels of brightness and has a sharp edge always, it could be scan module problem.
S. Mohan
Oct 05, 2009 | Canon DR 3080C Path-Through Scanner
DOCUMATE 510
check on the flat bed part along the top. there are two white strips that go side to side. the top white strip is wider than the bottom strip right underneath it. On the thinner of the two strips, check for small black marks, can be very small. This creates a black line in the document. You can clean it with a fingernail & a tissue
Jun 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Black Line
Take glass cleaner and clean the small strip of glass to the far right. If there is a speck on that strip of glass it will cause a line when it scans.
May 02, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Canon DR-6080 Path-Through Scanner Logo
375 people viewed this question
old marine
old marine
