Question about Thermador SC272T Electric Double Oven
F24 Error code and incessant beeping
After we are done cooking and oven is off it starts beeping and error code F24 appears.  The beeping will start and stop for up to one hour after we turn oven off.  Everything works fine, just can't stand the beeping.
  • 4 more comments
  • Anonymous Nov 11, 2008
    pushing the door closed stops the beeping temporarily, so I suspect it's a matter of the door not closing completely.
  • Anonymous Nov 21, 2008
    3 year old oven. Just started with exact same problem. Does seem to be some sensor connected with the door.
  • mcc199 Nov 21, 2008
    4 years old - finished baking and grilling yesterday turned oven off and it then started beeping with error code F-24.  We turned off the circuit for 30 minutes problem still there.  We have noticed the top oven door looks like its sagged since new.  I do not place things on the door.
  • Anonymous May 10, 2009
    We have a Thermador single oven and also experience the erratic beeping, like our oven has a mind of its own.
  • Anonymous Mar 26, 2014
    Will not stop beeping and showing code f 24.
  • Anonymous Mar 29, 2014
    F24 error and beeping, won't close fully and now lower oven does not come on- key pabuttons don't respond
    New Friend:
Being a software developer I guessed that the keyboard (the touch pad) was bad, because in my case one of the keys (the Top Oven OFF key) did not beep or work. So I went on the Thermador website and found the touchpad on the schematic. I ordered one yesterday from a firm called Mar-Cone in St. Louis, and it arrived today. It is a very easy replacement, and takes about 10 minutes. Happily it was a good guess, and it works fine. For the 27" SEC272BS/01 (stainless) the part # is 474083, and cost $189.20. They will express ship for $25.
Phew, we have 20 people coming for dinner on Thursday.
I'll be happy to let anyone know how to change the panel.
Posted on Nov 25, 2008
  • 2 more comments
  • tamara May 29, 2013
    I would like to know how to change the panel.
  • tamara Nov 30, 2013
    Please let me know how to change the panel
  • Lakeland Appliance Service
    Be sure to order the correct part number as these are model specific. Most of the touch panels are No Longer Available (NLA).
  • Dawn Jones Oct 12, 2015
    Thermador double oven F24 Error model #C302US. Beeping after using. I want to fix. Perhttp://www.fixya.com/users/mazalily it's part #474083. He said he'd be happy to help walk through repair. HELP!
I'm getting a f24 code on my lower wall oven...what to do?
Hi. Error code F24 indicates that the controller has failed to communicate with the lower convection fan and oven lights control board. If the error code persists, I would recommend connecting with an expert repair tech to assist further and the display board may need replacing.
Sep 26, 2014 | Electrolux ICON 30 in. Double Wall Oven
F24 code
In some cases I have had to replace both the touch pad and power relay board. Expensive! HOWEVER, I have, on occasion, found the wide ribbon from the touch pad to the relay board to be at fault. I have not found replacements for these as of yet. I have been able to "open" the ribbon to clean the contacts within and reassemble it to find everything working. Needless to say, my clients have been extremely happy with my ability to do so, saving them thousands if having to replace the entire unit.
I found the bad connection when the lighting was dim and I saw a "flash" at the point ribbon it inserted in the end piece. Hope this helps.
Jan 23, 2014 | Thermador Ovens
F-10 code and continuous beeping
Your board is going bad
Aug 25, 2009 | Ovens
F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Jan 24, 2009 | Thermador C302U Electric Double Oven
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Viking Electric oven beeping saying EOCGT v36 premiere poweringup
Sounds like leaving the door open has possibly cooked the controller. I would try a power cycle - power off at fuse for 5 minutes, then reapply power. If this doesn't clear it, you may need a new controller for it.
Nov 27, 2008 | Ovens
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Error code F1 and beeping
Means replace the $300 control board. And if your like me.....do it twice within 12 months.
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Thermador SC272T Electric Double Oven Logo
2,218 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
