Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
ERD30S- oven wont turn on
My electric oven wont come on when I turn in on to preheat. The control panel looks ok, the oven light comes on, the convection fan works, buit neither the main element or the broiler element come on.
I had the control panel replaced a year ago. any suggestions?
    Scholar:
  • 121 Answers
Hi! jpdufilho
Try tuning off the power to the unit for 20 minutes. If this does not fix the problem you may need a new control board/panel. If you have a lot of lightning in your area you should have several surge protectors in your house. All electronic devices need some type of surge suppression.
InMrFixIt
Posted on Nov 18, 2008
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
Temperature light won't shut off after oven top cools down?
the preheat light wont go off on my oven, and its not really hot. my oven light is on as well ,how do I turn off the preheat light
Nov 30, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Sf367lxss 2 turns off during preheat
F2 E0 is certainly a the error for a stuck key on the pad. Did you buy a new? If so you need to return it and have it replaced. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 09, 2013 | Whirlpool GR773LXSS - Stainless Steel...
Frigidaire FES367ASE Slide in range
Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
Sep 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Preheat worksoven wont bake
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Tappan 30IN ELEC IGNa Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
253 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
