Question about Uniden Cordless Phone
GE 27938GE7_C call waiting
I have the manual from on-line for this model and this is not addressed. Some other phones in the house one pushes flash or talk and the incoming call can be accessed without disconnecting the original caller...with this phone I hang up on both of them-please help.
Yes, I re-read the manual and it says (under Caller ID) to press the flash/program button to answer the new incoming call...I must have hit the pound key in error thinking I hit the flash button. I have yet to try this in real time, but will next time it arises and report if it does NOT work.
Posted on Nov 10, 2008
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Jun 17, 2008 | GE RCA 4-Line Speakerphone
My g.e. model 28111 series dect 6.0 dual handset speakerphone system keeps flashing (both on the handsets & one base) that a message awaits. I recently changed providers from shaw to telus & do...
GO into phone setup, and set it to the default setting and the message cleared and the light stopped flashing.
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps you
Best regards
Mar 14, 2011 | GE Lands Phones
Hi- I have a GE DECT 6.0 #28811FE2-A cordless phone, and the phone constantly says "Line in Use" when it is in fact just charging. At first I thought it was my phone line, but there is a dial tone when you...
You can download the manual for this phone from GE here. It explains (page 30) that the light remains on when the phone is charging or the line is in use, and flashes when you have an incoming call or waiting voicemail if you have that feature on your phone line. Your phone is working properly.
(This was supposed to be a solution. I clicked the wrong place.)
Mar 26, 2010 | Uniden Cordless Phone
I I have a cordless GE phone, model #279076E1A. The electric power went off in my house and the digital letters "CL" began flashing on the phone and wouldn't stop flashing after the power went back on. How...
That's telling you to set the clock which has lost time. Manuals are available from GE if you've lost yours. The model number you give is not valid, but here are links for the 27906 and 27907. If neither of these is yours you can pick your model from the list here.
Hope this helps. Thanks for using Fixya!
Feb 21, 2010 | Lands Phones
Hell There, We have a "legacy" GE hands free kichen" phone model: 26730GE1-D Yes, I know it's ancient, BUT I did put a fresh, brand new battery in last week and it rings, when piucked up reads out...
The calls are being placed on waiting, try using Flash button before using Talk.
Test the chance on a different phone line , the most likely is that the phone is defective.
If the phone is working on a different line, then it is a configuration problem, and the phone is waiting for a manual call transfer from a different phone in your network.
Try using Flash button instead of Talk, this will answer the call if there is a waiting service programmed.
Try testing with no other phone connected.
Finally try resetting the phone, use procedure below:
  • 1. Make sure the phone power is ON (but not in the “talk” mode by pressing the PWR button.
  • 2. Use the arrow buttons to scroll through the main menu until Handset setup is flashing.
  • 3. Press the SELECT button. A second menu shows on the display.
  • 4. Use the arrow buttons to scroll to Reset phone.
  • 5. Press SELECT.
  • 6. Use the arrow buttons to change NO to YES.
  • 7. Press SELECT to confirm.
If after resetting the calls are still being placed on hold, then again, the phone may be faulty.
Here a manual for your phone.
Jan 15, 2010 | Cell Phones
Phone problem
At the corded base set go to link handset go to 1 press flash/programm you will be asked to waiting for registration with handset, then go to handset go link base there also click on yes and again on flash/programm button you will be connected
Nov 27, 2007 | GE 25881EE3 Phone
go to then search the exact brand & model (not the serial number or mac address) of your phone unit.
Nov 03, 2007 | GE 29484GE2 Corded Phone
TReset for GE Pro Series Model 29451A
Remove the plastic speed dial card covering and the speed dial card. Press "program" with a pen tip. Press the intercom button. The lcd display says "address-xx" (probably out of range). Type in a new 2-digit address within range (the number of phones you have), probably 01, 02, 03 or 04. Then press the # key. The intercom light should turn green, and there you have it.
Sep 10, 2007 | GE 25413RE3 Corded Phone
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Uniden Cordless Phone Logo
85 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
