Question about Kitchen Ranges
We were trying to turn on the clean cycle on my Bosch range. The oven is locked in demo mode and we can't get it out of demo mode.How do we get it to turn on to the clean cycle?
I never got the help I needed. Waited hours! Very dissapointed!!!
Posted on Nov 10, 2008
How do i turn on the self cleaning device.
make sure the oven door closes fully, nothing preventing it from closing. Some brands want you to remove the racks from the inside of the oven before it will activate the cleaning cycle. once door is completely closed, select the self clean cycle and press start. if you have a lock that you manually have to lock (older style of ovens), you will have to lock it before it will enter into the self cleaning mode. most of the time, if there is an issue before you try to enter the cleaning mode, it should tell you on the display,...i.e...remove racks, lock door, etc. good luck. look for me on 6ya if you need more detailed help.
Nov 23, 2015 | Kitchen Ranges
MY OVEN WON'T HEAT
Hello - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failur
Oct 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven doesn't heat
Hi Sharon Knight - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Sep 17, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Bosch HEI7282U range. Went through self clean cycle, oven cooled down but oven door will not open. Put through another self clean, door still does not open. Cut power at circut breaker for over 5...
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut
Jan 31, 2011 | Bosch HEI7282 Electric Kitchen Range
Elextrolux Range stuck in Demo Mode
Phone agents and ask for workshops. Quote them the model and problem you have.
Jun 06, 2010 | Electrolux 30" Self-Cleaning Slide-In...
VIKING STOVE DOOR IS LOCKED AND WILL NOT OPEN , STOVE WAS IN A SELF CLEANING MODE AND DOOR WON'T OPEN AFTER CYCLE COMPLETE
unplug or turn off breaker to stove for 10 minutes...then try to gently open.....the oven has to be completely cool before it will unlock....when cleaning is done release lock before turning cleaning off
Nov 28, 2009 | Viking VGSC306-4B Gas Kitchen Range
We self cleaned our Bosch oven yesterday. Now the
I would check the following because during a self cleaning cycle a oven gets very hot and draws alot of power and this could of happened
Fuse/circuit breaker
Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker. Main wiring Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Nov 23, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Jenn Air oven door won't open after clean cycle
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Nov 26, 2008 | Jenn-Air SVE47100 Slide-In Electric...
DEMO mode
Push and hold the "timer off" pad for 5 seconds until you hear two beeps.
It may need to be the Stop or Clear pad, but the principle is the same.
Nov 27, 2006 | Bosch HGS436UC Gas Kitchen Range
Demo Mode
press and hold the mode button for more than five seconds. Then use the knob to scroll to "Default". This sets the stove to normal operation.
Dec 09, 2006 | Bosch HGS435UC Gas Kitchen Range
Kitchen Ranges Logo
196 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
