Question about Lexmark X2500 All-In-One Printer
Lemark printer
Pinter will not feed paper
  • farhansyed Feb 21, 2009
    my printer not loading paper properly when i am sending print job its print job is complete but paper do not get in
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Apr 25, 2009
Here is what fixed my Lexmark X2500 paper feed problem. I was totally unable to dissassemble this unit. I soaked about 4 sheets of 8 1/2" x 11" standard printer paper with rubbing alcohol. Just about the first 3 inches or so. Using the paper feed button and with the printer on allowed the printer to feed these soaked pages inside. It took a little effort to get the lightly soaked pages into the mechanism. Also with the printer off I shoved (for lack of a better term) the soaked pages in and pulled them out several times and noticed dirt and black marks left on the paper. I have since (just now June 25,2009) finished up the 5 page print job I needed to complete and a 2 page test print job. All is OK.
Hope this alcohol trick works for others....
Posted on Jun 25, 2009
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
My pinter is an X4270. It prints well, but will not feed the paper to fax, scan or copy. I keep getting a clear paper jam reading, but there is no paper jam.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 07, 2011 | Lexmark X4270 All-In-One InkJet Printer
Pinter iP2600 says I have a paper jam and wont feed paper. I see no paper jam but paper wont feed.
perhaps if you got a paper when you try to remove jammed paper to a piece of paper rupr remained on paper route, and have seen where, if paper was not broken when it is possible that when you pulled a paper to be skipped sensor that never returns to the starting position
Apr 12, 2011 | Canon Office Equipment & Supplies
Paper jam on kodak pinter but no paper is in pinter and keeps saying paper jam
make sure to fan all sheets several times before loading, both from the 8.5" side, and also the 11" side. fixed my problem. hope it will fix yours
Sep 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
PIXMA MP780 All-In-One InkJet Printer: Getting Printer Error 6A00 light on pinter flashin...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 07, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Small plastic piece that holds spring on paper feed in main paper tray broke. Need replacement part or service.
lemark calls this the bell crank ofr the autocompensator 56p1331 lexmark want 27.00 use l-tech4u.com you can get one for 7.00 delivered email for parts not posted
Sep 24, 2009 | Lexmark Optra T612 Laser Printer
Pinter keep stating that it is jammed. I lift up the cover and there is no paper than click on OK. It keeps stating that there is a stuck paper. What else can I do??? No support phone number either!
Hello sir;
go to find out where is the paper sensor, you will find out there have a small paper chip stuckover there. the paper sensor right in front of paper feeding roller .
Aug 06, 2009 | Kodak Office Equipment & Supplies
When i try to copy(works fine otherwise) on a lemark x6170 paper feeds part way and then gives me a jam message.
You can get free live support for this problem by going to:
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:383:0:0
Aug 03, 2009 | Lexmark Office Equipment & Supplies
Lexmark X2500 All-In-One Printer Logo
431 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
