Question about Panasonic CXDVP292 Car DVD Player
It's dead!! Got this factory fitted to a Jaguar Sovereign. It had a dvd stick in it, which was successfully prised out, bur bith before and after that, it was completely dead. No lights, reset didnt help, wont do anything. There's power in the relevant wires in the power connector. Do these have any sort of internal power protection - internal fuse etc? The only other thing i need to check is that there is no problem with the earth wire, but any other advice would be useful
SOURCE:
snakehead
  • 1074 Answers
SOURCE: power problem
yes it is worth repairing take it to a tech the problem is in the power supply,goodluck.
Posted on Mar 30, 2007
MicrowaveSvc
  • 9156 Answers
SOURCE: Microwave went dead
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
You should also check the high voltage rectifier diode to be sure it's not shorted too: http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can find an authorized Panasonic servicer here. You can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
Posted on Nov 07, 2008
Palmbeach
  • 185 Answers
SOURCE: Removed and replaced internal fuse - unit is now dead
Hi
The chances are that you bridged the printed track with a splash of solder when you replaced the regulator. A short circuit like this will cause the fuse to blow. You can get replacement 20mm slow blow 2amp fuses quite easily. But before you fit a new one, pull the board out again and have a very careful look under a magnifying glass at your solder joints. Get a small stiff bristle brush and carefully brush across the joints in case there is a tiny ball of solder across two points. When you reassemble the unit, ensure that the ribbon connectors are central and fully pushed into the sockets. I'm sure you can recover your DMR E55 reasonably easily. Best wishes
Posted on Dec 25, 2008
  • 1527 Answers
SOURCE: Panasonic TV Tube type TX-32PD30. Loud bang -
hello check the glass fuse in the power supply inside the tv
regards
shaun
Posted on Jan 19, 2010
Testimonial: "already found PC lead point on PC bd with apparent fuseholder bearing resistor(?)inaccessible without removing most internals.At front nr on/off. Help"
  • 6771 Answers
SOURCE: We have a Panasonic NN-CT579SBPQ. Using it last
The microwave oven needs to be replaced, the magnetron is the most likely problem, there is also a high voltage transformer, capacitor, and diode that are potential issues. But by your description it sounds like more than one part is involved.
Posted on Feb 23, 2011
Testimonial: "Very quick reply."
Ignition key will not turn in cylinder .. it is frozen have tried jiggling lubricating ,shifting ,turning wheel etc ... no results
the tibs ignition key barrel has worn out and/or key you need to get a new barrel and key or a kit that you can reassemble yourself so the origional key will fit if its not worn out. go to your jag dealer these parts may not be availiable. easily try jaguar heritage website
Jul 16, 2017 | Jaguar Cars & Trucks
Warn light box on theright side of dash don't show any simbols ie door open, seat belt not fitted etc but flashs amber.
the common prob with old xj40 with odd readings on insrument pack is bad connection inside the pack itself with good eyesight carefull dismantling and a soldering iron it can be fixed
May 13, 2017 | Jaguar Cars & Trucks
When I do a kick down in a 00 XJ8 Sovereign. It seems to be hesitant and the same when you kick down when the S button is engaged. If you build up the speed gradually, then kick down it seems ok
Kickdown switch not working....is this common? - Gassing Station ...
www.pistonheads.com/gassing/topic.asp?h=0&f...t...
PistonHeadsThe kickdown switch on 2000 model XJ8 3.2 Sovereign is not working. Based on members experience is this likely to a faulty switch or a computer problem? More results from www.pistonheads.com
XK8 Sluggish Performance
www.jaguarforum.com/showthread.php?t=76206
Nov 19, 2014 - A 2002 XJ8 SE, A 2000 XJ8 Sovereign, and a 2000 XK8 Coupe. ... If I only press the throttle pedal a little way, there is no kick down and the car ... Misfire, Lumpy running??? - Jaguar Forum.co.uk
Apr 3, 2015
Proud new owner of a Jaguar XJ8
Nov 21, 2014
Misfire/slight hesitation under hard acceleration - Jaguar Forum.co.uk
Feb 13, 2012
S-Type 3.0 SE Hesitant on Kickdown - Jaguar Forum.co.uk
Apr 7, 2008
More results from www.jaguarforum.com
XJ8 and Kick-Down - JaguarForums
Dec 16, 2015 | Cars & Trucks
1994 JAGUAR WILL NOT START FUEL PUMP NEW WILL NOT KICK IN NOR WILL THE COIL FIRE COIL IS GETTING POWER AND FUEL PUMP ALSO LAST TIME IT WAS A RELAY TO THE BRAIN
Similar problem on my 1994 Sovereign; found earth post next to left hand fuse box corroded; (large grommet in inner wing just above fusebox is prone to leaking so sealed with mastic)cleaned and fitted additonal earth to new point on body, now runs fine.
Aug 23, 2013 | 1994 Jaguar XJ6
How to remove trim and panel to replace inside left door handle assembly for 1995 Jaguar XJ6?
There is a square plate, behind the chrome opener, prise this out and there is a screw behind it, there are screws in the bottom of the arm rest, the rest is just on plastic push fit rivits so the door card should just gently pull or prise free.
Jan 27, 2010 | 1995 Jaguar XJ6
I had a radio a jvc r301 given to me as a birthday present and it does not fit my car a jaguar sovereign 1997 can you help
You will need to modify the connections if it is not a like to like option.A multi meter will be needed to assist you here.Now if the radio itself does not fit the bay,then it's a bigger problem..
Aug 26, 2009 | Car Audio & Video
Recode factory alarm keyfob for 1989 jaguar
you have to take it to the dealer you cant do it your self
Jul 17, 2009 | 1988 Jaguar Xj Series
Factory Fitted CD player. 1994 Jaguar XJ6
i think there may be a fuse located on one of the wires thats attached to the radio itself, you will have to pull the radio to check it
Jun 17, 2009 | 1994 Jaguar XJ6
Changing Door Mirror Glass XJ6(X300)
Hi
You need to put on a pair of gloves, and safety glasses. (Safety First !)
Prise off the broken mirror from the plastic base that it is stuck too.
Give the plastic a clean with nail polish remover or similar.
Peel off the backing on new mirror glass, and carefully stick it on.
Good Luck !
Don´t forget to FixYa Rate Me Please !
John.
Feb 05, 2009 | 1998 Jaguar XK8
Panasonic CXDVP292 Car DVD Player Logo
51 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
