Question about Jl Audio 12W3 Car Subwoofer
No sound No continuity No Ohm
Is there solution for blown speaker to repair.
I did check with multimeter, No Ohm rating and No continuity.
Please Help.
Have a nice day!
Michael Noh
michaelnoh9@yahoo.com
  • 79 Answers
Sorry no there isn't.
Posted on Jan 22, 2009
Sound is only coming out of one side of my earthquake sub. Could I have blown the other side? Thank you
That's certainly a possibility, but there are others, like a wire coming out of the terminal, etc. First step is to pull the speaker out and check it with an ohm meter. If there's no continuity it's blown.
Jun 11, 2016 | Earthquake Sound Audio Players & Recorders
No woofer sound from my K3000FX. Verified all cables and settings correct- but sound only comes from tweeter. What could it be?
Step 1:
Hate to say it, but possibly a blown speaker. To check this, do the following -
Step 2:
Insert headphones into jack to verify for sound there.
Step 3:
Unplug unit and open rear panel to reveal speakers.
Step 4:
Remove leads from woofer.
Step 5:
Using a multimeter, set to OHM (horseshoe) to lowest setting.
Step 6:
Apply red(+) and black(-) to speaker leads. Meter should read at least 4-8 ohms of resistance.
Step 7:
If no reading, then voice coil is blown.
Step 8:
If no meter available to use, the use a 9 volt battery by applying direct connection to speaker leads in an off-and-on fashion - You should hear a "click" sound come from speaker. If no "click," then speaker is blown.
Step 9:
If click is heard, and resistance on meter is correct, then the amp circuitry leading to the woofer may be blown = repair needed.
Jan 18, 2013 | Behringer Ultratone K3000fx 300w Keyboard...
Hi Thanks for your help, One year old Sony mini
sir i think ypur unit is ok and run correctly... try to check your speaker maybe your speaker got open or burnt... you can test it by swapping your speaker to another unit or you can test your speaker using multitester...just point your selector at resistance test a speaker has 8ohms reading....
the speaker has a two terminal.. a positive terminal and a negative terminal... your multitester has a two lead.. red lead which is a positive and a black lead which is negative..
measure-speaker-impedance-1.1-800x800.jpg Multimeter probe sockets (NL Graphics) Insert the probes of a digital multimeter in the correct sockets of the multimeter. There may be several different sockets for the probes depending on what parameters you're measuring. Look for the sockets marked "impedance" or displaying the ohm symbol. Different models and brands of multimeters will vary in their labeling, so check your multimeter's manual if you're not certain about which one to use.
  • 2 Select the range for the multimeter. Since you'll be measuring fairly low resistance levels with a speaker, choose a range that will encompass readings in the 2-16 ohm range. It's extremely rare to find speakers that will have an impedance outside of that range.
  • 3 Touch one probe to each of the speaker terminals and check the reading. This will be the impedance of the speaker. Record the measurement, and when you're done, turn off the multimeter to preserve the batteries for the next time you need the multimeter.
  • Read more: How to Measure Speaker Impedance ' eHow.com http://www.ehow.com/how_5068180_measure-speaker-impedance.html#ixzz1OsNOPSq3
    if you think this help please rate me thanks...
    Jun 10, 2011 | Sony CMT-HPZ9 Shelf System
    The jvc kdr310 protected mode problem what to do to fix it
    Check the ground wire to the amp, if you have a multimeter, set it to continuity and check the ground lug on the amp to the frame of the car, if there is more than say perhaps .1 ohm, i'd check the ground.
    You could have also blown out a fuse or two on the amp it's self. That may be a better place to start.
    Dec 04, 2010 | Car Audio & Video
    No Power :(
    It does sound like it may be blown but most likely you can have it rebuiltor reconed check local listings for speaker repair or audio repair and so on. I have a repair shop here in town which is Denver. Also keep in mind that a repair shop may not use a high quality parts to complete the repair. New may be better. One more thing if you know how to use a multi meter try OHM testing the woofer check to see what the rated OHM's are and also test with it powerd up and powered off. Hope this helps. If so please leave feedback.
    Jun 10, 2010 | Altec Lansing VS3251 Speaker
    4 ohm speakers with 8 ohm receivers
    Please check with the manual of your receiver whether it is capable of running 4 ohm speakers.
    if yes, then please go ahead, you will not loose any Sound quality. Sound quality will depend a lot on the performace of the speaker as well as the frequency range it can deliver.
    If no, please do not connect. Though, you might be able to play and listen to the music, but it will overload your receiver!!
    If you are not sure, please let me know the brand and model of your receiver and I can check for you.
    Please do rate this solution and thanks for using FixYa!
    Mar 06, 2009 | Yamaha HTR-5990 Receiver
    Hy when hooking up right rear speaker to purlpe wire coming from radio causes radio to shut down?
    Pinched wire, metal touching metal, or blown speaker.
    Try and move the speaker up and down. If it is hard, or you hear scratching - it is blown.
    You can test for continuity to ground on the wire with a multimeter that has continuity capabilities as well to see if there is a problem.
    Thank you for using FixYa - A FixYa rating is appreciated!!
    Jan 23, 2009 | Car Audio & Video
    Amp quit putting out sound
    It is probably in the "protect" mode. When this happens, the amp will have power going to it and seem to be turned on, but no sound. Many amplifiers have a LED that is normally red and it lights up when in the protect mode. Check all the LED's on the amp and see if one of them is for the protect mode.
    When an amplifier goes into protect there are usually only 2 reasons for it.
    1. A bad speaker
    2. A channel blown inside the amp.
    Disconnect the speakers to the amplifier and see if it makes the amp come out of protect mode. If the amp has an LED to indicate when it is in the protect mode, this LED will shut off, and sometimes they have a relay inside the amp that you will hear click. If you hear the click sound form inside the amp after you disconnect the speakers, you probably have a bad speaker. Take yours to a service center and ask them to check them for you, many shops will do this for free, I know that my shop will do it for free, so I assume that many others will also.
    If the amplifier has a blown channel, you need it serviced. There is no quick fix for a blown channel. If you have a multimeter I can tell you how to check some of the components inside to verify if it has a blown channel. Let me know if you are able to do this and I will give you instructions on how to properly test the components. If you do not have a multimeter, there is really no way to figure out what components are bad. Your only choice would be to take it to a service center for repair. They can give you an estimate of what it may cost before you are committed to paying for a repair. Most car amplifiers will cost about $100 to $150 to repair a blown channel. It just depends on how much damage there is, and the rates of the service center.
    I hope this is helpful, and if so a good rating would be appreciated. If you need to communicate more with me to determain what the problem is, please wait to give a rating until we are finished. That way I will not get an undeserved bad rating. By the way, the only rating that is good (meaning that it doesn't lower my over-all rating) is a FixYa! rating. The "Helpful" and lower just bring my rating down. After all, the only reason for offering this free help, is to get a good rating.
    Dave
    Nov 18, 2008 | Jl Audio 500/5 Car Audio Amplifier
    Blown subwoofer
    "Is there any way to repair voice coil?"
    the simple answer is no.
    the long answer is you could try contacting the mfg of the sub and see if you can order a new foam ring, cone and voice coil to replace the one you will have to destroy to take it out.
    Nov 09, 2008 | Jl Audio 12W3 Car Subwoofer
    No sound
    Either you have a wiring issue or defective speakers. If you have a multimeter, set it for an ohms reading. With the speakers disconnected, ohm the terminals. It should read very close to the ohm rating of the speaker (as indicated in the specs).
    You may also check the fade control on the deck to make sure it's balanced between front and rear.
    Hope this helps!
    Aug 31, 2008 | Pioneer DEH-P4800MP CD Player
    Jl Audio 12W3 Car Subwoofer Logo
    108 people viewed this question
    Top Jl Audio Car Audio & Video Experts
    Mark Skinner
    Tygh Duval
    Tygh Duval
    hoyzee1
    Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
