Question about Sharp 25N-M100 25" TV
Nothing works i have a 25"sharp teleision model # 25f-m50 the tv stopped working the other night chcked the fuse in the rear of the tv it was blown after several blown fuses from radio shack found out the fuse was a specile one it was a slow blow fuse found the correct fuse and replaced it only to hve it blow again please help
    Sergeant:
  • 337 Answers
The fact the set blows up the correct fuse is because it has a short ahead in the circuit,it could be one of the diodes(4) that is shorted,if one of these guys is bad all of them should be replaced with the exact replacement,ahead of them it should be a regulator and he is bad (shorted) it could have taken the diodes and the main fuse.The cause might have been a power surge.If you are familiar with tv service you can check the regulator and the diodes before you put in a new fuse,if you are not too familiar be safe and take the set for an estimate.If you suspect power surge or lighting damage it might not be worth repairing.Let Us know if you need more information.
Posted on Oct 26, 2006
  • Omar Urrutia
    Omar Urrutia Oct 26, 2006
    Your rating response is also important.
My Sharp Aquos LC-26D44E-GY in the spare room has stopped working. It worked ok about 2 weeks ago, went to switch it on last night & its dead. We had a thunder/lightening storm last week? Ive changed...
First check your power outlet, try connecting the TV to a different power outlet. Then see whether the LED light on the TV is on or blinking. Anyhow, this might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
Sharp t v 25r-s100 no power the t v is not turning on
This can be caused by one of two problems. EIther the fuse is blown which is located inside the rear panel next to the power supply aka power inverter. Or the power inverter/supply itself is bad if the fuse is good. It can be tested with a voltmeter.
Dec 31, 2010 | Sharp 25R-S100 25" TV
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Protron PLTV-3250 doesn't turn on
May be the power fuse.
Older CRT sets had an external chassis-mount fuse holder at the rear.
Nowadays, many sets have the fuse on a power / control board inside.
If fuse is blown, renew with an identically-rated match.
This protects the TV.
Oct 06, 2017 | Televison & Video
HOW TO ADJUST COLOR WITH NO REMOTE
YOU CAN TRY THE MENU BUTTON ON THE CONSOLE.USE THE VOLUME UP/DOWN BUTTONS TO SELECT THE FUNCTION.BETTER YET,JUST REPLACE THE REMOTE WITH A UNIVERSAL ONE.THEY ARE INEXPENSIVE AND ARE REALLY EASY TO SET UP.
Aug 17, 2008 | Sharp 25R-S100 25" TV
25f-m40
i do not know but i at one point had three of theses tv's at once have an extra
Aug 13, 2008 | Sharp 25K-M100 25" TV
Television won't come on
Could be as simple as a blown fuse, but if you know so little about TV's, go see a serviceman!
Mar 27, 2008 | Durabrand DWT1905 TV
25" Sharp tv
check fuses if the seconary fuse blown then posible bad fly back
Nov 01, 2007 | Philips 27PS60S 27" TV
Sharp 25N-M100 25" TV Logo
137 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
