Question about Olympus Stylus 700 / 700 Digital Camera
OLYMPUS STYLUS 740 ALL WEATHER
Is it worth it for me to fix my camera or just buy a new 1. Does not turn on. batter door broken and lense cover also broken but works.
    Novelist:
  • 150 Answers
If it works, use it as long as you can.
Fixing snap-shooters is generally not worth it,
since digital cameras evolve rapidly and lose
value even faster with age.
Martin
Posted on Nov 12, 2008
Where can I buy a new battery door for a gold oly stylus 35mm f2.8 fixed lens camer
There are several models of Olympus cameras with 35mm f/2.8 fixed lenses. There is a list of available parts, including battery covers, here.
Nov 24, 2011 | Olympus Infinity Stylus 35mm Point and...
Olympus stylus 740 when the camera is turned on
There is probably a setting on your camera that prevents you from writing to the card. There may also be a switch on the card that prevents the card from being written to.
Jul 16, 2010 | Cameras
BATTERY COVER DOOR BROKEN OFF OF A C740 ULTRA ZOOM OLYMPUS CAMERA
Hello :
Check these links for purchasing another one : Link1 , Link2 .
I hope this will help .
Please don't forget to rate !
Jun 10, 2010 | Olympus Camedia C-740 Ultra Zoom Digital...
How do I replace an Olympus Stylus 710 Battery Door?
Please visit this site and order a new batterydoor for your Olympus camera www.lutoncameras.co.uk
regards Rob NL
Apr 15, 2009 | Olympus Stylus 710 Digital Camera
Dropped camera when kens was out
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Feb 16, 2009 | Olympus Stylus 740 Digital Camera
Shutter v soft
Are you talking about the sliding door that powers on the camera and covers the lens?
There is a metal plate with two screws on the bottom of the sliding door that holds the door to the camera, try tightening the screws and see if that helps. Or else see if the door is slightly bent out of shape, and try to bend it back if you can.
This is a common problem on the Stylus-300 camera, you can buy a replacement door from eBay -
http://cgi.ebay.com/Olympus-Stylus-300-Camera-Parts-Repair-NEW-LENS-BARRIER_W0QQitemZ250147262921QQihZ015QQcategoryZ64352QQcmdZViewItem
Nov 19, 2007 | Olympus Camedia Stylus 300 Digital Camera
Olympus stylus 710
I just wanted to follow up that we ordered the replacement part from the website another poster listed:
http://www.digitalcamerapartsdepot.com/Olympus_Parts/VK127200.asp
The part came in three days and it was SO EASY to replace. You just need a tiny Phillip's head scewdriver and about three minutes. Remove the three small screws that attach the faceplate to the camera (one on the bottom, two on the side). The faceplate pops right off and exposes the hinge that holds the battery door in place. Remove the final screw that holds the hinge in place. Reuse the original spring, pop the new door in place and then replace the faceplate.
Just like new! :)
Nov 09, 2007 | Olympus Stylus 710 Digital Camera
Card cover.
The cheap, instant way is to tape it down - pvc electrical tape is probably the best for this although it will get sticky after a while. La fa?on bon march? et imm?diate est d'utilisez du Scotch / bande ?lectrique PVC - le deuxieme est probablement le meilleur pour ceci bien qu'il obtiendra collant un peu plus tard. if you want to replace the cover then contact Olympus Europe on this link; si vous voulez meme remplacer la couverture contactez Olympus Europe sur ce lien ; http://www.olympus-europa.com/consumer/208_1562.htm another way to go would be to find a local dealer or two and ask them if they have any C-740 that has a good card cover but is otherwise unrepairable - you might get lucky. Une autre possibilite est de trouver des n?gociants local et les demandez s'ils ont un C-740 qu'a une bonne couverture de carte mais qu'est autrement irr?parable - vous pourrait avoir de la bonne chance. Hope this helps - please ask again if not :) J'esp?re que ceci vous aide - demandez moi encore si non (mes excuses si vous n'?tes pas wallon) :)
Jun 23, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Broken camera
It is likely that your lens assembly was knocked out of alignment when you dropped the camera. When things do not line up inside the lens the whole unit cannot move in and out. This malfunction requires disassembly to fix, so you will have to get it to a professional for repair. There are providers online who can repair your camera, and also check with your manufacturer to see if they can service the camera at a reasonable rate. David Millier Advance Camera Repair
Mar 05, 2007 | Olympus Camedia Stylus 300 Digital Camera
Olympus Stylus 700 / 700 Digital Camera Logo
142 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
