Question about JVC AM FM CD DET FACE CAR STEREO
No sound from sterio when engine is reved.
No sound fom sterio when engine is reved, but ok if lights,heater ect are on.
Have to turn off sterio then back on to get sound back.
    President:
  • 624 Answers
This sounds like you have a problem with the voltage regulator in your car. Normally it is part of the alternator. Does your lights on the inside and outside of car get dim when the engine is idle, and do they get brighter when you rev the engine? Does your battery gage go way down when the engine is idle and then go way up when the engine is revved up? These are all signs that the regulator is not working.
The radio will only operate normal at the proper voltage, if your voltage regulator is putting out too much voltage when the car is revving, it can make the radio malfunction.
Have the alternator/regulator in your car checked. It may just be that part needs to be replaced.
Posted on Nov 10, 2008
This may sound weird but the last couple weeks I have been hearing a reving noise which sounds like its coming either inside my dash behind the speedometer panel or inside my hood. It sounds like a remote...
details given lead me to belive that your climate control or fan of your heater is worn...normally just wear after years and do what you are saying....so try turn off off off all heater or cooler fans and go for a drive...other than that you've something wrapped around a driveshaft causing the noise...
Apr 30, 2014 | Cars & Trucks
Service engine soon light on 171 174 surging idle
Hi try this video it may help you find the fault it covers the codes on 4.0l engine. Ford Explorer 4 0L SOHC Rough Idle P0171 P0174 Lean Codes
Jun 23, 2017 | 2000 Ford Expedition
Toyota Yaris SR over reving when changing fom 1st to 2nd less from 2nd to 3rd.
Retrieve the engine and transmission fault codes, if any.There could be many reasons. But to start with, check the transmission oil level and catalytic converter.
Oct 05, 2012 | 2009 Toyota Yaris 1.3
Dashlights not working-97 mustang gt
sound like a lose wire.take dash back out and check the wires that goes to dash.wires could have move out of place when you removed the dash.
May 26, 2009 | 1997 Ford Mustang Cobra
Starter makes weird noise dosent turn over
Starter drive not engaging fully . Sticky or worn, but don't think changing thermostat had anything to do with it. Try having starter drive inspected & lubed if possible , but you may end up with new starter.
Dec 22, 2008 | 1998 Pontiac Sunfire
1987 RCA TV
most like the amp on speakers wwent bad best u can do add seprate samsng sterio suround system or ect form dish cable box to sterio direct for tv sound or rca outs on tv if those sstill work
Oct 06, 2008 | RCA E13309 13-Inch Diagonal XL-100 Color...
2000 Intrepid turns over no spark
"No Bus" usually means you have a bad ground. Check the condition of the battery ground, clean it if necessary. Check other grounds as well.
Jun 10, 2008 | 2000 Dodge Intrepid
HDMI SOUND PROBLEMS
yes u guys nee dto do all the hdmi directto tv then optcal digital back to sterio digital in for sound only ect not throw sterio kills picture also
Jan 30, 2008 | Yamaha RX-V661 Receiver
SURROUND SOUND
does sterio system have aux in tv has rca outs use rca cable from tv outto aux in on sterio system ok the selct aux input on sterio turn it up
cheak tv settings for outout options ok
Jan 19, 2008 | Aiwa NSX-A115 Shelf System
JVC AM FM CD DET FACE CAR STEREO Logo
55 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
