Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune front load washer (top of the line)
My washer will fill with water but when it is time to start the wash cycle, it won't turn at all in wash or spin cycle, I only here the sound of the motor running. If I can turn the knob to spin, it will only drain the water no spinning action. My wife said she heard a clink-clank sound and smells like something burnt?
Some of the early washers had problems with a weak or faulty motor . take front panel loose and look at motor board it may look burnt on some of the resistors or look at the clear fuse at front of board it may be burnt if so use a motor/board conversion kit p#12002039.
Posted on Aug 29, 2007
Maytag neptune washer can not change the wash cycles
1) test the timer probably faulty,tight connection wires see the diagram how to test,and see the diagram in line black, how the contacts from timer control everthing in the washer.
2) problem of cold water, is the cold water turn on? consult your owner manual for to see if acting abnormally
3) check the selector is o.k
God bless you
Jul 18, 2012 | Maytag Neptune MAH6500A Front Load Washer
Won't progress beyond wash cycle -- start light is flashing. Cannot switch from "normal" to delicate or any other choice. Maytag Neptune TL FAV6800AW
So I understand the issue. Does the wash cycle start up? By that I mean if you release the washer top from the base do the tumblers turn once the water fill cycle is complete?
If you don't have the FAV6800A/FAV9800A Service Manual (you can't get it on line anymore) see this post Clutch Fix I describe how to release the washer top from the base to observe the wash basket. Don't raise during the water fill cycle wait till that completes.
Does the key pad beep as you press the other cycle select key pads?
This could be a Control Board issue...........Rich
Oct 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
MAYTAG NEPTUNE TOP LOAD DOES NOT FILL TUB WITH WATER HEAR NOISE BUT NO WATER AND STOPS AND 24 MIN QUICK WASH CYCLE, NOT SURE WHERE TO START.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag neptune front loader
check the following
power cord plugged into a grounded 3 prong outlet
the inicator on the cycle conrol knob proprely lined up with a cycle? turn the knob to the right slightly then pull the knob
are you using a extention cord if so dont
washer overloaded
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
May 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
168 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
