Question about Mitsubishi WT-46805 46" Rear Projection Television
The green fades in and out
When i turn the TV on 90% of the time the green is out and then suddenly we will get flashes of green to come into the screen or it will turn the TV bright green suddenly. We were tol by some one to take off the front screen and look for dust on the bulbs. How would we be able to take off the screen and see?
  • Mitsubishi Master
  • 8,617 Answers
Its most likely caused by a bad solder joint on the Green CRT dive board which is located on the bootom of the green CRT ( Center CRT) which you can accesss by removing the front speaker panel then the small access pane behind the speaker panel. If the solder appears good the green CRT itself is most likely defective.
Posted on Jan 08, 2009
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Suddenly turned off without warning Sony KDS-50A2000
All you need is to open the back cover of the television and check on for dry soldering at the power stage of the printed circuit board, also check for bulged capacitors, if found replace with same rating of voltages , but if otherwise Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
Hope this helout, Good luck....
Jul 11, 2010 | Sony KDS-50A2000 50" HDTV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Power flashes green then turns red; Lamp flashes red.
is this a flat screen first off
if it is 90% of the time the vid card has over heated they have a video card kinda like pc's one thing is most companies dont put fans on them so they over heat especially when dust start collecting on it wait and see if anyone else has any thoughts on this but im pretty sure thats it you will need to take it to someone that works on tvs to replace it and also ask them if they will install a fan on it
but like i said wait and see if anyone esle has any thoughts on this first
Apr 28, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
RCA D52W20 52 in. Rear Projection
the main pwr board is defective and will need replacement...
Oct 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
This is a common problem and a local repair place shouldnt charge more then 90 to 125 bucks to repair. Its the tuner and tuner sheilds that need to be resoldered. Theres even an RCA service bulletin about this repair. At one time RCA was giving out rebate coupons if you had this repair done for future purchaces of RCA products but Im not sure if they still do this . Good Luck
May 06, 2006 | RCA F25645 25" TV
Mitsubishi WT-46805 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
