When openeing my computer i get a windows explorer error also whenopening folders
No sound on my compaq presario notebook pc (c302nr). I accidently dumped my hp audio. please help me. I'm a techno illerate!
Posted on Nov 09, 2008
L did,t get a work manual with my computer and l don't know how to insert a cisk
Which operating system ?
If its a cd or dvd disc you are referring to there is a horizontal slot on the front panel of desktop computers just insert the disc into the slot once it gets half or three quarters of the way in the computer should find it and drag it into the computer .
Then access this disc in windows explorer.
Click start all programs accessories open windows explorer my computer you should see your drives C: usually your hard drive D: your cd dvd drive and your usb drive E: or F: click to open it
Windows Explorer is an application that enables you to locate system files, folders and components on your computer. It enables you to make adjustments on components installed or running on your computer. It provides detailed information about your files and folders and enables you to organize them by renaming, copying, or moving them. You can launch Windows Explorer in several simple ways.
Right-click the Windows "Start" menu and click "Explore" to launch Windows Explorer. You should see the system folders in the left panel. Click the folder that you want to launch. You should see the contents of that folder on the right panel. Alternatively, launch Windows Explorer by double-clicking "My Computer" (Windows XP) or "Computer" (Windows Vista and 7) on the desktop. Click the "Folders" button on the top. You should see the system folders in the left panel. Click the folder that you want to launch. You should see the contents of that folder on the right panel. Alternatively, click the Windows "Start" menu and click "Programs" or "All Programs." Scroll up and select "Accessories." Click "Windows Explorer" to launch Windows Explorer.
If you need more help with this post a reply
Mar 04, 2013 | Acer Computers & Internet
Tip
Desktop Short Cut Missing
Hello,Some times your Desktop shortcuts or Start Menu Disappeared.It is happening due to Error Occurred in Explorer.exe. You can Clear this Error without Formatting.Just Do Following..
  1. Copy "explorer.exe" from other clean computer (from C:WINDOWS)
  2. And Paste it In your computer go to C:WINDOWS
  3. Show hidden files from (Tools - Folder Options - View - Show hidden files and folders)
  4. Delete existing 'explorer.exe' and any other files start with explorer...
  5. Put the new file (explorer.exe)
  6. Log off / Restart
  7. Log on
OR Just try this Solution.Close all your Opened Windows/Programs(OR Restart PC). Just Run this Dos File.It will Restore your Desktop Surely.. I/we need your valuable Feedback...Keep Using FixYa
Check this Link............. "Unable to Open Theme Corrupted" in Nokia 6300 Click here
on Apr 11, 2010 | Computers & Internet
Tip
How to Restore Disabled Folder Pane in Windows Explorer
Problem:
When you open Windows Explorer, the left hand Folders pane is disabled or gray or blank and the folder tree on left is not available.
Cause:
There may be an error in the registry. A required system file is missing or an incorrect version.
Solutions:
Close Windows Explorer.
Start the Registry Editor (click Start, Run, type regedit and click OK).
Expand HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main.
In the right-hand pane, locate the value named ExplorerBar. If present, delete it.
Restart Windows Explorer. If this does not resolve the issue,
The correct solution depends on the version of Internet Explorer that is installed on the computer.Internet Explorer 5.5 or lower
The preferred solution for computers with Internet Explorer 5.5 or lower is to upgrade to the latest version of Internet Explorer.
If this is not possible:
Open the folder C:\Windows\System. Check that the file browseui.dll is present. If it is not present, restore this file.
Internet Explorer 6
Open the folder C:\Windows\System. Check that the file shdocvw.dll is present. If it is not present, restore this file.
Open a command prompt.
Enter the command cd \Windows\System
Verify that the command prompt shows C:\Windows\System.
Enter the command regsvr32 /i shdocvw.dll.
Enter the command regsvr32 /i browseui.dll.
A message will appear confirming the successful registration of the files.
Now restart the sytem and confirm the problem is solved.
on Jan 17, 2010 | Computers & Internet
Spooling subsystem error. I can print some things but some things get stuck and I cannot even delete them.
Click "start" and go to "Run"
Type "services.msc" at the prompt which will open the Services
window.
Scroll down the alphabetical list in the right window pane until you come
to the entry with the name "Print Spooler"
Right-click this entry, then select "stop". This will stop the computer
running the process that holds your print queues.
Leaving that window open for now, click again on "Start", and then click
"My Computer" to open a Windows Explorer window.
We've stopped the queue service, now we just have to clear the jam that is already there. To do this we navigate to the print spool folder which is hiding within the Windows folders. Usually Windows is installed on C: drive, but you should be able to tell when the Explorer window opens which drive it is on.
The usual path to the spool folder is C:\WINDOWS\system32\spool\PRINTERS, but yours may be slightly different. Your windows drive may have another name for instance, but this would be uncommon. So click on your Windows drive (usually C), then double-click on the Windows folder, and then find the System32 folder and double-click on that. Windows may warn you that you are about to view system files, but click "View files anyway" message and search out the "spool folder". Within the Spool folder is your Printers folder, and you should open that.
Delete every file within this folder to empty the jammed print queue (pressing the "ctrl" and "a" keys will select all files and then you can just hit "delete").
Close the explorer window now that we have emptied the cleared spool files and return to your Services window. We must re-start the Printer spooler service, and do so by right-clicking the Print Spooler entry and selecting "Start" from the list. Close the services window and try printing again.
Mar 25, 2011 | Computers & Internet
Windows explorer opens in ''my documents''. Running XP
Hi there and welcome at Fixya, the support team (lfete)
Windows explorer open in a default Folder and at your computer it opens in My Documents- folder, you kan also open windows explorer in Start (and) Music, Documents, Pictures and My Computer- folder.
Hope it helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
Mar 09, 2010 | Computers & Internet
Tip
Set a new Windows Explorer launch folder When you run Windows Explorer, it...
Set a new Windows Explorer launch folder When you run Windows Explorer, it always opens to the Libraries folder. That's fine if you use Microsoft's default file organization, which designates Libraries as the overall container for your folders. But what if you don't? You might prefer to have Windows Explorer open to Computer or any other folder you choose. Here's how to do it:
1. Right-click the Windows Explorer icon on the taskbar (it's the one that looks like a folder), and then right-click the Windows Explorer icon from the context menu that appears and select Properties. The Windows Explorer Properties dialog box appears.
2. You'll have to edit the Target field on the Shortcut tab of this dialog box in order to change the default location at which Explorer opens.
If you want Explorer to open to a specific folder, simply enter the name of the folder, substituting your folder name for Folder, below, like this:
%windir%\explorer.exe c:\Folder
So to open Explorer to the folder named Budget, you would type this in the Target field:
%windir%\explorer.exe c:\Budget
If you want Explorer to open to special, pre-set locations, such as Computer, you'll need to enter special syntax in the Target field. Following is a list of three common locations and the syntax to use, followed by the syntax for the Libraries folder in case you ever want to revert to the default.
  • Computer: %windir%\explorer.exe ::{20D04FE0-3AEA-1069-A2D8-08002B30309D}
  • My Documents:%windir%\explorer.exe ::{450D8FBA-AD25-11D0-98A8-0800361B1103}
  • Network: %windir%\explorer.exe ::{208D2C60-3AEA-1069-A2D7-08002B30309D}
  • Libraries: %SystemRoot%\explorer.exe
3. After you've changed the Target field, click OK. Next time you launch Windows Explorer, it will open to the new location you've designated.
on Jan 12, 2010 | Computers & Internet
Outlook express frozen-up
To resolve this problem follow the steps below:
  1. Open Internet Explorer.
  2. Click Tools and then click Internet Options.
  3. Internet Explorer 6
    • Under Temprorary Internet Files click on Settings button.
    Internet Explorer 7
    • Under Browsing History click on Settings button.
  4. Click Move Folder and change Temprorary Folder to different location.
    Note: Make sure do not place the temp folder on C:\ or systemroot drive.
  5. Optimize Internet Explorer.
  6. Close Internet Explorer.
  7. Try to open Outlook Express again. To resolve this problem follow the steps below:
      Internet Explorer 7
        Internet Explorer 7
      Note: Also create a new folder in drive by the name of temp and selct the location of this folder when you click on move folder.
    Note: if you get the message that temp folder already exites then rename the temp folder and create a new folder.
    1. Optimize Internet Explorer.
    2. Close Internet Explorer.
    3. Try to open Outlook Express again.
    good luck.
Nov 13, 2009 | Computers & Internet
Artcopy 55?
To resolve this error, complete steps A and B below. Step A:
  1. Open Windows Explorer.
  2. Go to C:\Program Files\LexmarkX73.
  3. Delete the Artcopy55.jac file.
  4. Open the Scan & Copy Control Program. (Go to Start, Programs, Lexmark X73, Scan & Copy Control Program.)
    The file will be rewritten with the latest settings.
Step B:
  2. Go to C:\Windows\Twain_32.
  3. Delete all folders except for the Lexmark folder.
  4. Reboot the computer.
Note: If completing the above procedure doesn't resolve the problem, JETSOFT recommend reinstalling Windows XP as a solution. (JETSOFT is the company that developed the Scan & Copy Control Program.)
Apr 10, 2009 | Lexmark X73 All-In-One InkJet Printer
Windowslive messenger not responding keeps coming up error8100030d
Error: 8100030d If you are receving the error code 8100030d when signing into Messenger, do the following: 1. Determine what version of Messenger is installed on the computer, and then upgrade Messenger if it is required: 1.a. Click here to determine the most recent versions of Messenger for each operating system. If you are not running the latest version for your operating system, please install the most updated version. 2. Delete the cache files for Messenger. Follow the steps below based on which version of Messenger you are using: 2.a. For MSN Messenger: 2.a.i. If you are running Windows XP or Windows 2000 click Start, click Run, type cmd , and then click OK to open the command window. 2.a.ii. If you are running Windows 98 or Windows ME, click Start, click Run, type command , and then click OK. 2.a.iii. At the command prompt, type the following commands. After each command line, press ENTER:
cd\
cd %appdata%\microsoft
cd "msn messenger"
del /s listcache.dat 2.b. For Windows Live Messenger: 2.b.i. For Windows XP
  • Right click on the Start button and then click Explore to open Windows Explorer. On the Tools menu, click Folder Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Click to clear the Hide extensions for known file types check box . Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them
C:\Documents and Settings\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts\ Your Messenger email address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
2.b.ii. For Windows Vista
  • Click Start and then click Explore to open Windows Explorer. On the Organize menu, click Folder and Search Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Clear the Hide extensions for known file types check box. Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them.
C:\Users\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Users\ Your Windows logon name \AppData\Local\Microsoft\Windows Live Contacts\ Your Messenger e-mail address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
3. Try to sign in to Messenger again.
Aug 24, 2008 | Computers & Internet
Windows explorer error!!!
Have you tried clearing out your temp files?
Dec 18, 2007 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
