Question about Plantronics Discovery 925 Bluetooth Headset
Callers cannot hear me.
When I make or recive a call using my Plantronics Discovery 925. They all say that I sound very far away. But this is a new fault this is a problem that has just started to happen after my last charge.
thanks for any help.
  • 4 more comments
  • jzasowski20 Dec 13, 2008
    I just got my Plantronics Discovery 925, I charged it fully, successfully connected it to my phone, and made my first call. I could hear the person just fine, however, they could not hear me at all. I tried turning the headset in my ear to have it point toward my mouth, yelling loudly but still nothing. Any suggestions?
  • craftyone01 Jan 09, 2009
    I have the exact same problem....it started out so they can barely hear me, not they can't hear me at all????
  • jodalynholla Jan 21, 2009
    Same issue!! Was working fine for about 4 months now everyone says they can't hear me and I sound far away!
  • angorama47 Jan 23, 2009
    i've had mine for 9 months with no problems, and suddenly this week i can hear callers fine but they can't hear me unless i yell. if anyone finds a solution, i'm desperate!
  • Anonymous Jan 29, 2009
    I have the exact same problem after using it for over 3 months. I thought the problem was with my iPhone. So, I switched it with my Blackberry & still have the same issue. Logged the call with Plantronics for replacement but still haven't heard back from them yet.
  • justvalerie Feb 20, 2009
    I bought the 925 and it worked great for about 3 months then out of the blue callers couldn't hear me. I exchanged it for a new one! It worked fine, Ive only had this one for about a month, was working one night and the next morning same problem, callers could barely hear me! I even got a new phone, so it's not the phone's it the bluetooth! I called plantronics they sent me some troubleshooting tips! Nothing worked!
I've had the same problem where no one is able to hear me. I finally discovered by looking at the opening where the mic is that it was plugged up with debris. I took a soft brush (toothbrush) and cleaned the debris from the opening and and like magic it cleared it up. Everyone said I sounded fine and clear. Make sure the opening is clear of any debris and remember not to put the narrow part of the headset where the mic is located inside your ear canal. Use a cotton swab to clean your ear (lol)
I hope this helps
Posted on Apr 24, 2009
Same exact problem...Sorry!
Posted on Feb 13, 2009
925 is paired but has no sound
i had a similar problem. what had happened was maybe a piece of small lint or plastic got inside or broke off inside of headset and blocked the tiny hole at the tip. anyways, use a safety pin or anything small enough to unblock the hole.
Sep 22, 2012 | Plantronics Discovery 925 Bluetooth...
I have an LG phone and my Discovery 925 bluetooth from Plantronics won't connect anymore. When I have it in discovery mode my phones message states "no devices found."
You want to make sure that there is no other bluetooth interference on your phone and follow the instructions on the link for the Plantronics Discovery 925 (see page 4).
Good luck from Headsets Direct!
Jul 17, 2011 | Plantronics Discovery 925 Bluetooth...
Apparently the volume of my plantronics 925 bluetooth is very low. is there a way to adjust that volume? Thank you.
Yes, there is a way to adjust the volume on your Discovery 925 headset. See page iv to locate volume control button and page 8 for the instructions in this link for the Plantronics Discovery 925 User's Guide.
Jul 01, 2011 | Plantronics Discovery 925 Bluetooth...
I can hear the person on the other end, but they can't hear me on my plantronics Discovery 925
Try using the headset on a different phone. This will narrow down if it's a compatibility issue with your phone or a defective headset. If you pair to a different phone and experience the same dead microphone, that means the headset is the issue. If it's less than a year old, you can have it replaced directly from Plantronics. Plantronics tech support can be reached at 1-800-544-4660 x 5538.
Good Luck from Headsets Direct!
May 18, 2011 | Plantronics Discovery 925 Bluetooth...
When I make a call using the bluetooth, I can hear who I am talking to through the bluetooth, but they can't hear me?????
Make sure both devices are fully charged. Turn off your phone and disconnect the battery for about 30 seconds (this helps to reset the phone). Make sure there are no other bluetooth devices interfering with the connection. Turn off your headset and carefully follow the pairing instructions on the link below for the Plantronics Discovery 925.
May 12, 2011 | Plantronics Discovery 925 Bluetooth...
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
    until the headset begins to flash red and blue.
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    Lg lotus does not locate plantronics 925. have been using motorola h700 with no issues. have turned off phone and 925 and retried several times. lotus does not see any other devices.
    Once you make your LG Lotus discoverable, then put the Plantronics Discovery 925 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Discovery 925 pairing instructions.
    Plantronics Discovery Pairing Instructions
    Apr 27, 2010 | Plantronics Explorer 330 Headset
    When I am talking to someone on the phone i get a lot of static.
    see what TTY mode your phone is in. TTY mode is under call settings or go to voice command and say TTY mode. I keep mine off. This mode is for people who are deaf, and people who are hard of hearing and use hearing aids.
    Dec 12, 2009 | Plantronics Discovery 925 Bluetooth...
    Cannot get my 925 to work on my computer as an audio unit for use with Skype. Cannot find a driver that will work on VISTA 32bit
    Have you placed the 925 into discovery mode?  It will be flashing red and blue rapidly if you did.  Here's how to do it: Turn the headset off by holding the main button down until a red light comes on Turn it back on by holding that same button and keep holding it after you see the blue light come on.  Eventually it will start flashing red and blue.  This is now in pairing mode.  Set your computer (if it is bluetooth enabled) to find all bluetooth devices.  It should be listed as Plantronics 9xx.  If you need a passcode it's 0000.
    Apr 20, 2009 | Plantronics Discovery 925 Bluetooth...
    Plantronics Discovery 925 Bluetooth Headset Logo
    1,028 people viewed this question
    Top Plantronics Radio Communications Experts
    LeAnna Mathews
    LeAnna Mathews
    Level 1 Expert
    shaun taylor
    Michael Vincent Cruz
    Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
