Question about Pioneer DEH-1400 CD Player
Radio stations not beiing memorised
Just fitted a DEH1400r to my 1998 VW passat,keep having to reset all radio station whenever i get back in the car,Have fitted an ISO connector the original blocks and to the rear of the cd player, Any ideas would be much appreciated.
  • suzisi Nov 10, 2008
    thanks for that asish_shrm for your help with the deh 1400r cd player,if you swap the red and yellow cables it maintanes memory.
    cheers again suzisi
    Scholar:
  • 121 Answers
There is suppose to be 2 power in for the radio
1 that holds memory for the radio has to be picked from a line that has power available to it even if the car is switched off
and the other just to switch on the radio itself...
check to verify that you have connected the memory power for the radio correctly and that that line has power even though the car is switched off......
use dc tester to test that it has power available
Posted on Nov 09, 2008
  • Asish Sharma
    Asish Sharma Nov 10, 2008
    Thanx for voting!
My vw Passat 16 plate infotainment doesn't appear to be working, I have lost all radio stations bar a couple, it won't save them anymore, when I save one and stop the car lock it and get back in everything...
It has lost battery power. It has 2 power sources. The battery is constant, no fuse. This is for the radio memory. The ignition is fused, it is the one that turns the radio on. You have to pull the radio plug and check for battery power. If it is there, you have an internal radio problem.
May 04, 2016 | Cars & Trucks
Radio on 2013 Chrysler 300 keeps changing stations in ascending order
Have you turned off the power to the radio completely? This
can reset the standard operations...(turn radio off while car is on) then back on again...Hope this helps.
Mar 12, 2014 | Cars & Trucks
How do you assign preselect numbers to radio stations
You can assign radio station presets on your stock VW radio by tuning to the radio station you would like to preset, and then holding down one of the preset number buttons until the radio beeps. You will now be able to access the station by pressing the preset button.
Oct 15, 2013 | Vehicle Parts & Accessories
How do I preset different radio stations?
Hello
There are 6 preset position available for each radio band.
For programming, Radio must be ON. Tune to a station. Press MEMO/DEMO. Press any button 1 to 6. The tuned station will be memorised on the number you select by button press. Repeat using a new station and preset number. There is no atu preset option available with this device. You have to store stations you want according to your preference. Only 6 station positions for each band [total 12 positions] together with AM and FM bands.
To recall the stored stations, press the desired number 1 to 6.
Dec 07, 2011 | Sharper Image SI785 Clock Radio
Directions on how to set favorite stations on a 2003 pontiac sunfire radio
AM / FM RADIO
Setting Preset Stations
The six numbered pushbuttons let you return to your
favorite stations. You can set up to 18 stations (six AM,
six FMI and six FM2) by performing the following
steps:
1. Turn the radio on.
2. Press AM FM to select AM, FMI or FM2.
3. Tune in the desired station.
4. Press and hold one of the six numbered pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return.
5. Repeat the steps for each pushbutton.
RADIO WITH CD ( BASE LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 18 stations (six AM, six FMI and six FM2) by performing the following steps:
2. Press AM FM to select AM, FM1 or FM2
RADIO WITH CD (UP LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 30 stations (six AM, six FMI and six FM2, six XM1 and six XM2 (USA only, if equipped), by performing the following steps:
2. Press BAND to select AM, FMl, FM2, or XMI, or
4. Press EQ to select the equalization.
5. Press and hold one of the six numbered XM2. pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return and the equalization that you selected will also be automatically selected for that pushbutton.
6. Repeat the steps for each pushbutton.
Additional details could find in your Owners Manual; hope this helps (remember to rate this answer)
Jul 02, 2011 | 2003 Pontiac Sunfire
Cannot find FM Radio on Card
FM radio is ascertained with popular adveretsiments. For example, once ascertain that 106.10 transmits popular enterment media requires to restore to memory. Recent devices recognise the user requests by allowing to search at button feature functions until available signal broadcast were discoved also memorised on device. In situation that the device radio least has auto scan to capture require to manually tune until an available signal broadcast were recognised. Also with devices least with momory features requires to humanly keep to memory the radio frequency. For example 106.10 is recogniseable as party station.
Examples of radio stations
98.1 FM
99.3 FM
94.9 FM
102.3FM
Mar 02, 2011 | Computers & Internet
Entering radio codes for a 1998 passet
If you don't have MODE and SCAN buttons ( I didn't ) you can try as above but with TP and TA - they worked for me.
Feb 22, 2010 | 1998 Volkswagen Passat
I have a 2001 VW Polo with a factory fitted radio, cassette cd player. It's started to switch to the cassette player (which I've never used) and when I switch it back to the radio there's no sound. I...
Hey there! I had the same problem just the other day and removed the radio from the car over night.
Turns out the radio may have got too cold or a little damp! Whereabouts is your car stored overnight? Could be the reason why!
Either that or one of the buttons could be stuck. Hope this helps
Dec 06, 2009 | Car Audio & Video
Vw golf4 radio problem
Sounds like the head unit has internal failure, just check wiring ok at back first but probably will require replacing
Dec 11, 2008 | 1998 Volkswagen Golf
Pioneer DEH-1400 CD Player Logo
218 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
