Question about Whirlpool LER5636P Electric Dryer
Now no heat after working for a few weeks with a new heating element.
We had to replace the motor and got a new heating element, everything fine but now no heat what could be the problem?
    Genius:
  • 1,198 Answers
By the time a dryer has worn out a motor and element, the wire connections are old too. You are going to have to check every connection, especially the push-on type for tightness and corrosion.
Posted on Nov 25, 2008
Why the heat exchanger between the freezer section and the fridge section freezes up around the second element closer to the door and makes ice on the roof of the fridge section.
If your freezer is icing up it is the defrost mechanism consisting of the timer, heating element, and defrost thermostat.
When you unplug unit everything melts and it runs fine for a few days till it freezes up again.
Usually it is the heating element that just burns out and has to be replaced.
Sep 14, 2015 | GE Refrigerators
Not cooling
either your heating element for auto defrost is broken or your thermostat is is broken
Dec 09, 2013 | Frigidaire Refrigerators
Our Lakewood 5101 oil heater gets warm, but over the last few days, it is not getting hot like it used to. It seems like it has slowly been getting colder over the last week or so. I can feel the heat...
Appears you have a heating element issue. Many of these elements are segmented for temp control. If one part goes fubar the heater will work but not put out the heat it used to unless you replace the element with a new one that has no burnt out sections.
May 03, 2017 | Lakewood 5101 Oil Filled Radiator Heater
I have a Bosch HBN7053GB /05 oven which worked fine apart from the bottom oven does not heat up, the light and fan are both working just no heat. I have replaced the element but still no heat, so now im...
You changed the element does everything else work fine, stovetop elements,broiler etc.if so check your wiring going to the new element and to the switch if they are fine it may just be the temp/control switch
Mar 12, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
Heating element is not working
I would say it could be one of two things. The heating elements could be bad, not likely though as the were working when the dryer was reset. You may want to try changing your circuit breaker, as your heating elements work off of the 2 phase 240 voltage while everything else in the dryer works off 120V. Check the voltage on each phase of the breaker in your electric panel see if your putting out the full 110-120V per phase.
Jan 09, 2010 | Frigidaire GLER331A Electric Dryer
F-08 error message on Hotpoint Washing machine WT761? The original fault on the machine was that it was tripping out and taking out a resetable fuse in my fuse box a few seconds after turning the machine...
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
Oct 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
I have an similar problem with my Amana Dryer LEA30AW.
First Clean out your filter, Assuming the element is okay and cut-out are fine it should run okay, you could also try running it on low heat will take a bit longer but hey if it works great..Good luck
Oct 01, 2009 | Dryers
Dryer will not heat
Check to make sure you have 240V at the outlet. If you do, check the continuity of the element and thermostats. If still no heat, it could be the temperature setting switch, the timer or the motor.
Feb 19, 2009 | Kenmore 65924 Electric Dryer
Estate dryer electric, heating element gets hot but motor does
shut off power to dryer. take front off dryer,remove belt from motor and idler pully (if there is one) try turning the motor shaft by hand. if it doesn't turn ,take off back of dryer and remove blower housing and see if anything is blocking the impellers.. if not any of these then you may have to get professional help it may be a bad motor or timer
Jan 22, 2009 | Estate EED4300SQ Dryer
Whirlpool LER5636P Electric Dryer Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
