Question about Toshiba TEC B-472 Thermal Label Printer
TEC B 472 QQ
I have a "new" (refurbished) TEC B 472 QQ printer, and a TEC B-472-GH12-QQ-CFL printer. (I bought the wrong model) The only difference I can see is the B 472 QQ has just a serial connection while the other one has a serial, parallel, and a third connection I don't recognize. Is is possible to add a board to the B 472 QQ to make it parallel compatible? I have an old TEC B-472-GH12-QQ-CFL that I could pull the board out of and install in the B 472 QQ. I don't know what the difference is between these two models, but they look identical except for the missing connections. Can anyone tell me if this modification would work, or a better way to modify the B 472 QQ to work with a parallel connection. Or do I just need to find a a new B-472-GH12-CFL? Thanks for the help.
  • Anonymous Jan 26, 2009
    the same problem with TEC B-472 QP, printer is not recognized by computer
Swapping the parallel port to the printer should allow it to connect via parallel. Run through front panel diagnostics before/after install. depending on firmware it will tell you if the parallel board is installed.
Posted on Mar 26, 2009
Tec b-472 gap sensor
use detection transmissve in the driver
Aug 13, 2012 | Toshiba TEC B-472 Thermal Label Printer
In the display show the next message: "PROGRAM
This is due to your microswitch or firmware problem.
Check if switch 1-7 and 1-8 are off
Otherwise your printer needs service
Aug 11, 2011 | Toshiba TEC B-472 Thermal Label Printer
I had to change the ribbon in our B-472-QQ and now the print quality is very bad. Can hardly read the label. Tried changing the ribbon again, same results. Any help would be appreciated.
First of all.
B472 uses a near edge technology for printing.
You must use Ribbons for near edge head.
- You must use a WAx/resin for paper labels and Resin For Polyester or plastic labels.
You may also have your print head mis-alligned or you are not heating enough
Jul 12, 2011 | Toshiba TEC B-472 Thermal Label Printer
With the tec b472 qq ..i get mesage RC000;W-13807 DO U KNOW WHAT THAT COULD MEAN ..THANKS
this means that you have a field missing in your label definition.
Ypu must have a PC000;XXXX,XXXX,etc field defined first
Feb 04, 2011 | Toshiba TEC B-472 Thermal Label Printer
Expansion i/o interface TEC b-472-qq
With a dB24 port here is the minimum
DB24 to DB24
2 to 2
3 to 3
7 to 7
on a db9 to DB24
2 to 3
3 to to
5 to 7
Xon/xoff and
9600 bds
8 data bits
1 stop bit
Xon/Xoff on the microswitches
Apr 07, 2009 | Toshiba TEC B-472 Thermal Label Printer
How to adjust print head temperature on TEC B-452-HS12-QQ
it depends if you are working with driver, label software or escape commands. If you are working with escapes you can try with command AY, refer to the programming manual.
If you are working with Seagull driver you can adjust the print density in OPTIONS
Oct 28, 2008 | Toshiba TEC B-472 Thermal Label Printer
Tec 472 qq no print
I can only guess there must be a problem with a setting either within the printer or your pc. It's unlikely to be a hardware fault as the printer self tests ok.
I have repaired quite a few of these printers, but haven't had your problem. I can only suggest your compare the settings (baud rate etc)
May 19, 2008 | Toshiba TEC B-472 Thermal Label Printer
Tec 472 qq no print
First of all can you print just from the printer ie
Turn on the power while
holding down the [FEED]
key and [PAUSE] key?
May 18, 2008 | Toshiba TEC B-472 Thermal Label Printer
TEC 472 QP PRINTER
Try with CUPS --- oh, sorry, it's for Linux only, my bad
Jan 08, 2008 | Toshiba TEC B-472 Thermal Label Printer
Toshiba TEC B-472 Thermal Label Printer Logo
935 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
lancer284
Level 1 Expert
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
