Question about GE 24 in. GHDA960K Built-in Dishwasher
Diplomat adp 8322 not heating fault 3
Diplomat ADP 8322 is 18 month old and has stopped heating water. At the end of the cylce the far right light flashes in 3s and it beeps
How to reset the programmer on dishwasher
Disconnect power for longer than 45 seconds.
Sep 17, 2009 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Diplomat adp 8520 dishwasher no hot water
two things to check
check continuity thru heater
remove outer door panel and check for faults in wiring loom
get back to me is these are both ok
Nov 14, 2008 | Dishwashers
I have a Diplomat ADP 8520 dishwasher (possibly SMEG manufacture) which will not stop trying to empty. There are 4 leds lit reading left to right and it beeps. I have read on some forums about pressing the...
fault is probably water in the bottom tray operating the anti-flood device. take bottom front panel off and mop out the water and it will work. if fault reoccurs then you have a leak
Nov 05, 2008 | Dishwashers
Diplomat Dishwasher Model ADP 8132
Please can you give me the dimentions of this Dishwasher Diplomat Model ADP 8132, as I have got to get a replacement and have been told that the Hotpoint FDL570X is the replacement offered,Many Thanks,
Mar 28, 2008 | Dishwashers
Diplomat dishwasher adp 8322
i had same problem and have found that under the lower basket the connecting bar to the spray arm had become detached this can be reattached by inserting the two nozzles back into position and pushing down youll see what i mean ! however i have found i now have to do this after every wash ,am currently onto diplomat to rectify this completely , hope this is any use.
Mar 09, 2008 | Dishwashers
GE 24 in. GHDA960K Built-in Dishwasher Logo
132 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
