Question about Jandy AQUALINK RS TELELINK KIT
Jandu Aqualink Pool/Spa Controller RS6
Cannot reprogram. Pool is covered and the spa is still open. Cannot program spa to come on automatically. I tworked before we closed the pool. Do you have a link for the operation of this computer?
  • 125 Answers
I have an Aqualink RS6 with a Jandy 6473-E control panel and my spa is being commanded ON without being told to. It will not do this when I have service mode selected at the power center. Thanks
make sure there are no spa programs if no programs remove the spa side controller plug if ok then replace spa side remote water could have damaged the wires
Sep 27, 2015 | Jandy Pool & Spa
How do I cancel a program and reprogram the Jandy, Aqualink RS6
go to system set up then go to program highlight what you want to change then edit or delete program
Jan 02, 2014 | Jandy Pool & Spa
6520 rev hh
check red 4 pin connectors to see if any wires touching if not make sure wires are tight also make sure wire isnt cut or knicked sometimes landscapers do it not knowing seems like shorted wire if you can take controller with shorter wire and try next to aqualink if it works bad wire if not bad controller
May 01, 2013 | Jandy Aqualink RS6 Pool Only/Spa Only...
I have Aqualink RS6. Screen is lit, but no display. Is they some thing I can check?
Check to see if all 4 wires are connected inside the controller (your inside wall unit) and also at the power center outside. After removing the cover outside you will see a red 4 terminal strip (4 wires) above the buttons. Above the buttons is low voltage, below the buttons where the relays are is high voltage, be careful.
Your inside controller (cover pops off from below) has the same red terminal strip that hold the other ends of those same wires. If you have a later model it may use a telephone type connection.
If it all looks good call a pool tech who should have a portable controller, he can plug in outside to see what happens. Good luck with it.
Jan 28, 2013 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
Aqualink RS6, 6700 rev c message
check to see if wires are cut or shorted if ok need new controller
Apr 30, 2012 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
Jandy rs6 all button stuck in spa mode
take off front cover of controller sometimes the buttons stick if ok need new display board
Mar 17, 2012 | Jandy AquaLink RS2/6 All Button Dual...
Freeze protection interrupts spa operation in cold weather
the filter pump is used for other features during spa use disable the freeze protection but turn back on after using spa
Jan 01, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy AQUALINK RS TELELINK KIT  Logo
573 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
