Went to site for manual but codes were blurry tried 3 and they didnt work, then did the five steps, turned on dvd, press setup, press dvd, press on/off repeatedly then the dvd went off and i pressed enter button to set. but when i try to turn dvd back on with remote it wont work nor will it make the dvd fast forward or anything
Hi. This is the best link I could find when I couldn’t find my codes for the TV. There is a manual and also the codes if you need it. If this isn’t the same remote I still think this is the best website probably.. I’d try typing in the remote control # in the search bar thingy if it’s not. Also, since it's small look up at the tool bar and there should be a magnifying glass or a plus sign, click on that and it will enlarge it, and also try the 4 digit codes listed, that's what I had to use.
Hope this helps, if not sorry!
Summer
http://www.jascoproducts.com/support/universal-remote-codes.asp
Universal remote allow you to control multiple
electronic devices with a single remote. You can use the remote to work
your TV,DVD player, cable boxes and other devices from the comfort of
couch.Philips is a popular manufacturer of universal remotes.to program a
GE remote for SONY TV,you will either need to input the device
code or perform a code search
direct entry
first.turn on your TV manually. next.press down
and hold set-up on the remote.the red indicator light will stay
lit.after that.press the TV device button to let the remote know you
wish to program a television then.enter your device four digit codes on
the remote..GE list several codes for SONY television including 0002 0006 0007 0018 0107 0114 0310 0312 0502 0601 0704 0719 0803 0806 0810 0901 0911
..if your remote needs 3 digit codes remove only the
number zero in the beginning of the codes finally.test the remote to
ensure it works.with the turned on,press the channel button and see if
the TV responds..if it is work the remote programmed and you are done,if
it doesn't work try the different code......
IF THIS SOLUTION HELPS YOU PLEASE DON'T FORGET TO RATE MY ANSWER THANK YOU
what kind of player is it
