Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
How do you open the cook top
Whirlpool ceremic top electric stove
  • 370 Answers
A glass top stove has a sealed top so you cant open it. Sorry for the bad news.
Posted on Nov 18, 2008
On the stove each eye has to settings you can either turn on single high medium or low or dual high medium or low I don't own the front I don't understand what that means what does that mean
It has two sets of elements, a single one in the middle if you a cooking a small item, or dual elements that cover a larger area for cooking large items. This works for the top hobs, and also for grills/broilers in many stoves. If save electricity, and also having heat outside the base of a small pan. I see yours says 'Accusimmer', so it is a Whirlpool and it is the top hob.
If you Google
make model manual
You will probably find it online. Here is some information
whirlpool accusimmer manual Google Search
Feb 21, 2018 | Kitchen Ranges
How do i change a whirlpool model wbp88800 burner control
Unplug stove. There should be two screws under edge of the cook top. You need to open oven door to get at them. Remove screws, lift cook top up at the front and prop it up. There will be two or three screws with spring clips holding the burner to the cook top. Unplug the connections, remove screws, remove burner. Install in reverse. I did this at Christmas just in time for dinner. It takes about ten minutes.
Feb 06, 2015 | Whirlpool Kitchen Ranges
My Maytag glass cook top PER5710BAQ stove has broken cook top are the similar product model tops compatible or do I need to buy the exact top... IE could I buy an amana cook top or whirlpool since they are...
It will depend how the tops electrical terminations are. Many internal/fuses/switches/elements are the same, but though may tag is the parent manufacturer it always isn't interchangable. Like a Pontiac g6 and Pontiac sunfire...
They're both 2 door cars
Both made by Pontiac
Some parts are identicle
But some aren't.
Nov 12, 2014 | Kitchen Ranges
Cook top light will not go out even with all burners off on my whirlpool WFE361LVS. any ideas?
Light usualy stays on till the stove or stove top Cools off give the oven time to cool off If this dos`nt do it turn the Breaker off for a while to rest it and see if no help check owners manual for a user`s GUIDE
Aug 29, 2011 | Whirlpool WFE361LVS Stainless Steel...
I believe there is a mouse nest in the insulation of my whirlpool ceramic stove top, how do I remove the stove top to clean it out?
Open the oven door and locate the screws under the bottom of the front edge of the cook top. Remove the screws and the cook top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
If there is evidence of any rodent infestation, make sure you do a thorough inspection of all internal wiring. Mice love to chew on wire insulation. Any bare wires can result in appliance failure, electric shock, or become a fire hazard. Make sure you do not use the range until repairs are made if there are signs of any wire damage.
NOTE: Ensure you also check the wiring inside the operator console. Remove the back panel to access.
If you have questions, please let me know. I hope this helps you.
Aug 01, 2009 | Whirlpool Accubake RF362LXTS Electric...
PF on Whirlpool super capacity 465 electric Stove Model RF366PXGW2
PF = Power Failure. Sounds like you have a bad electrical connection. With your breaker off, check that the connections from the cord to the range are all good and tight. Next, check the receptacle where the cord plugs in. Remove the cover and check the connections there as well. Examine the power cord also. There could even be a poor connection at the breaker box (at the circuit breaker or the neutral buss bar) but not as likely, as your problem appeared when you moved your range.
Oct 19, 2008 | Whirlpool RF378LXKS Electric Kitchen Range
Whirlpool gold stove (wd sensor open)
on my stove i pushed the lock button for my oven now it want unlock. it is like it is froze up, it want let me cook or anything
Oct 04, 2008 | Whirlpool GY396 Electric Kitchen Range
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Mar 13, 2007 | Whirlpool RF365 Electric Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
206 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
