Question about SanDisk Sansa e250 MP3 Player
My e250 is stuck
When i turn it on it goes to the opening sandisk screen. after that it just keeps turning off and turning back on, going to the same screen everytime right before it turns off. it just keeps reseting. when i plug it in nothing will read it at all and it doesnt make the mp3 player stop reseting itself. it just keeps doing it.
  • 85 Answers
Sounds like it was'nt safely ejected and is damaged
Posted on Nov 11, 2008
Can not turn off. Screen stuck on "SanDisk" logo
Take the back cover off and remove the battery. If there's a memory card in it, remove it also. Let it sit for a minute and put the battery back in and turn it on. If it still doesn't turn on and locks up, then take the battery out and plug it into your computer with the battery out. Copy everything from the device and format it. Unplug it from the computer and put the battery back in and see if it turns on.
Feb 11, 2011 | SanDisk Sansa e250 MP3 Player
My sansa e250 won't turn off and it's stuck on the
The software gets stuck. You just keep on pressing the menu button and center button for two to three minutes it will switch off automatically .
Hope it works .
Thanks for using Fixya.
Jan 23, 2010 | SanDisk Sansa e250 MP3 Player
My Sansa e200 will turn on, thumbwheel is blue and SanDisk screen comes on, but menu won't come on. I have pressed and held the power/menu button down for app. 15 seconds several times to no avail. It is...
sandisk sansa e250 starts but then says refresh database. Menu is in back ground. Maybe frozen, and have tried to reset, but still come up with Refresh database.
Sep 27, 2009 | SanDisk Sansa e250 MP3 Player
Sansa MP3 player has frozen screen
With the Sandisk you can just open up the battery compartment and pop the battery out for a second, then if you put it back in and turn the mp3 player on, it should work just fine. This is easier to do with the older ones that take AAA's, but unfortunately with the e250 you need a little screwdriver to remove the battery. (But the other day I used the flat part of a piece of jewelry; you can use whatever you have :D )
Sep 27, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player starting problem
Do a Firmware upgrade first - http://www.sandisk.com/sansa/#/support-0/
Enter Sansa e200 series
If this does not work, try the other methods I suggest in my Sansa player "Tips and Tricks" - click on My Profile if you do not see the article in the solutions section (no offense to Fixya, but your website is not yet user-friendly - needs some work).
Jun 11, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa goes to blank screen. No display and not working
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 26, 2008 | SanDisk Sansa e250 MP3 Player
My sansa isnt working anymore
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 14, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e250 mp3 player is not turning on and charging.
i had the same problem.  the solution i used was to unscrew the back and pop the battery out and put it back in.  the only other option is to wait for the battery to die, which can take a while.  it's definitely a flaw with the sansa.  its happened twice within 6 months...  good luck
Oct 20, 2007 | SanDisk Sansa e250 MP3 Player
Black screen
i dont know what the problem might be but u should try calling sandisk they should know what to do. hope it helps
Jul 11, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
122 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
