Question about Linksys Wireless-G WRT54GS Router (e125894)
Reconfigure Linkys G Wireless Router
I have recently purchased fast access DSL from AT&T. I previously was with Comcast and have been experiencing trouble connecting to the internet. I can connect as long as I bypass the router and have been told by AT&T that it is a Linksys problem. I have contacted Linksys and have been told that I need to reconfigure the router for AT&T rather than Comcast. It was at this point they told me my router was out from its warranty and that they would help me if I was to purchase tech support from them for $29.99 (one time) or 39.99 for six months. They of course recommended the latter. Doesn't seem to me to be a question of warranty so if someone could help me with reconfiguring my router I would be most appreciative.
    Scholar:
  • 132 Answers
  1. Make sure that your modem is connected to the WAN port of the router and your computer is connected to one of the 4 ports of the router.
  2. Check the IP address that your computer obtained from the router. To do that, go to control panel>network connections.
  3. Right click on Local Area Connections and click status. Then click support and look for IP address.
  4. The IP address of the computer should be in 192.168.1.x.
  5. Then, access the router's setup page by launching Internet explorer and typing 192.168.1.1.
  6. It will then ask for a username and password. By default there is NO username and the password is admin.
  7. Once you're in setup page, set Internet connection type to PPPoE.
  8. You should have the username and password from ATnT.
  9. Save the settings afterwards and check your Internet connectivity through the router.
Hope this helps!
Posted on Nov 09, 2008
Powerline adapter wont work with directv dvr
Different modems have different configurations - your new provider should be able to assist you in getting connected.
Sep 14, 2017 | Powerline Ethernet Network Adapter
A problem has occurred when trying to access the internet. Please check your DSL/Cable connection and verify your internet connection settings. Wtf is this ? Firmware update doesnt helped. .
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
Oct 27, 2012 | D-Link Dlink Dir-600 Wireless Router...
Router communication with cable modem
If you change service providers, connection type and hardware, then all your previous connection settings will not work, and they'll have to all be reconfigured.
Have you been given a new modem/router (combo unit)?
Did you previously have a separate modem and a separate router?
Do you connect your xbox via WiFi?
Go back to basics now. If your computers connect fine, then connect the xbox using an ethernet cable and see if it works. Then try wireless.
Feb 27, 2010 | Belkin (F5D7230-4) Router (587009)
I have an AT&T Modem; having trouble with internet connectivity
It is OK to keep putting the UN and PW in. However you shouldn't have to. I suggest having a tech come to your home and have them do a signal test both at your jack and outside with your home unplugged from your service box. If there is a big difference in the numbers then you're simply loosing signal due to signal bleed inside. This is a simple fix. Have them isolate some wires in your jack and place a DSL filter outside. Then your DSL signal will go straight to your modem and not bounce all over your home. This will NOT affect your phone.
Dec 31, 2008 | AT&T High Speed DSL Modem
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
WIRELESS INTERNET ACCESS
You don't have to purchase anything. Just plug a lan cable from your laptop to the DSL Router.All you need is a lan cable.
takecare.
May 05, 2008 | Toshiba P205-S6267 Notebook
Problem with connection to router and DSL
I would go to run and type in cmd. then type in ipconfig, I believe that is right for windows 98. I would look on there and see if that is getting a correct IP and if the DNS server says 192.168.0.1 if it is a belkin router. ipconfig /? will give you the commands you can use with that. There is a ipconfig /renew that will refresh them all. You might have it set to be a static IP and you would want it to be dynamic and have it refresh by itself. You can go to http://hippo.colorado.edu/info/ipsetup/staticip_setup.cgi?os=win98 for directions to change it to dynamic, I would just do the opposite of what they suggest to make it auto config. It sounds like it is looking for a previous DNS server which is not there anymore because the DSL connection reset.
Dec 20, 2007 | Belkin (F5D7230-4) Router (587009)
Cant get internet connection
When you suddenly can't connect to the Internet, any of several things could be wrong.
I think you should be to connect different Internet connection for getting fast speed. Even I am also facing problems with the Internet. I am angry for facing soo many issues again and again. So I changed my connection and my sister suggested me to look at the mungi site. There you get all the useful services and fewer expenses. If you also need an Internet connection at less price so connect with best nbn plans. They are providing so many offers in plans.
Dec 16, 2007 | HP Pavilion dv4000 Notebook
Linksys Wireless-G WRT54GS Router (e125894) Logo
54 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
