Question about RCA HD52W59 HDTV Projection Television
No power i was watching tv and it went off and went to turn on ,nothing i seen that the fuse has blow and put a new one in but still no power
  • 1 more comment
  • jrmrob Nov 13, 2008
    no the2nd fuse didnt but i still have no power
  • jrmrob Nov 17, 2008
    i still cant get no power
  • Jeff Costello Nov 22, 2008
    I have the same problem with my R52WH74YX61
    were is the fuse located
    Thanks
    Sergeant:
    Champion:
  • 346 Answers
Did the fuse blow the second time?
Posted on Nov 12, 2008
  • cyriacus joseph Nov 13, 2008
    check the horizontal transistor -(2sc5588)
  • cyriacus joseph Nov 17, 2008
    there are 3 small red rectangular shape objects near the flyback transformer .these are fuses .one of them may be open. the pins of the transformer needs to be soldered. there are also 3 capacitors(electrolytic) that needs to be changed if they look swollen.the location number under the green circuit board is cp150 cp114,cp120
    In order to solve these problems you need a qualified tv technician
Blowing fuse on tv
hi there's dead short in the power supply somewhere could be a number of components usually diodes or transistors cause this fault
hope it helps
regards
shaun
Jan 04, 2014 | Magnavox 32MF301B/F7 32 in. LCD TV
Toshiba tv no power
I have never heard of or seen a "power down button". Unplugging the TV and holding the power button for a minute or so sometimes will do a hard reset on the TV, is that what you seen?.
On your problem, chances are there was a spike that came down the power line when your power went out and it took out at a minimum the main fuse in the TV, you can remove the back and replace that fuse on the power board and see if it comes on or blows the fuse again, if it blows then look for a bad rectifier or shorted FET transistor in the hot section.
Nov 26, 2017 | Toshiba 32AV502R LCD TV
Tv went out when power went off, will not come back on
You NEED 2 go to a RETAIL Store, and purchase a SURGE PROTECTOR. It MUST have a switch, maybe a lit switch. When NOT watching this TV, TURN the POWER OFF. This WILL save burnout of the POWER transformer, and NOT use electricity, saving U money. When turning on this tv, U MUST have an electric Fan, to blow air across the electrical boards. This too, will add LONGIVITY, to the overheated electical circuits. I hope this helps.
Nov 29, 2012 | Toshiba Televison & Video
TV will not turn on, 3.15amp fuse keeps blowing on power board
I have an ln40b630n1fxa and my fuses keep going out as well i took it all apart and seen nothing blown. What would be my next step
Nov 06, 2012 | Samsung LN40B630 40 in. LCD TV
I have an Insignia 42" plasma HD tv. It turned off while watching it. when I tryed to turn it back on I could her click on and I got the green light but it went to red and i could hear it click off. I...
Those transformers on the power supply board have shorted.That why,it killing ur fuse.Which one?Must test and find out,if u have the equipment and the skill.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Sep 08, 2010 | Televison & Video
I have a protron PLTV 3250 I was watching Tv and the TV went out.
no it is your power supply it may have primary power but if you look closely you will see several puffed up capacitors these blow because of the fet near by let go and is not avail you can get a new supply for about 60 bucks from ramplus.com get the fsp number off the supply ex fsp-194
Sep 18, 2009 | Protron PLTV3250 32 in. LCD Television
No power to tv
The power management and protection circuits have taken over. There is something taking too much current and the protection system has shut the system OFF to prevent further damage ...............if you are familiar with tv service you can check the main fuse that should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as soon as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply.......Check horizontal output transistor.............
Feb 04, 2009 | RCA HD52W59 HDTV Projection Television
NO POWER
have the power supply checked it may have gone bad.
Aug 25, 2008 | RCA P52926 52" Rear Projection Television
Tv will not turn on
Yes, it is most likely the fuse. I have seen many of the fuses in those Panasonics "pop" for no apparent reason. If you feel comfortable, you can replace that fuse yourself. Carefully remove the back, follow the AC power cord and where the AC cord attaches to the PC board will be a small glass fuse. It is most likely a GMA 6.3A fuse. Replace that fuse and the set should work. If the original fuse is good or if the new fuse blows out too, have the set serviced by a qualified tech.
Sep 02, 2007 | Panasonic CT-32SX31 32" TV
TV will not power on after powering off.
There is no reset button on these new sets,your set has complete power problem since you have no lights no clicks,this might have happen because of lightning or power surge,either one creates a lot of damage,if you are familiar with tv service you can check the main fuse,he should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as sonn as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply,if you are not too familiar you should seek the help of a servicer a least for an estimate but if you suspect power surge or lighting damage dont invest any more on this set and get a new one.
Aug 30, 2006 | Hitachi 32UX01S TV
RCA HD52W59 HDTV Projection Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
