Abit SG-80 Motherboard
Problem for Abit SG-80 Motherboard
No Booting to BIOS, Monitor just stays on Save
By Richy on Oct 26, 2006
hi guys,
i recently bourght all the parts for a desktop and put it all together myself, installed XP home SP2 correctly with no fails or problems, all hardware is installed correctly aswell. a problem arised when it wouldnt boot even to BIOS and i tried it with just the CPU and RAM (using onboard graphics).
Later on it Randomly started working again (thiswas bout month ago), but i recently bought a new case and the problem has yet arised again!
iv already returned the SG-80 mobo, and this is a replacement.
iv cleared the CMOSS memory and checked the BIOS battery, iv also reinserted grease for CPU and checked if hardware is connected prperly about 58475 times!
should i just randomly keep trying it?
thnaks
Comments:
Oct 26, 2006
- it doesnt get to BIOS, it just stays on save. the monitor doesnt seem to read anything through the onboard gc or the ATI G Card.
all the system seems to do s use the DVD Drive. It uses it then stops then uses it again then stops, iv never seen this before.
thanks
Oct 26, 2006
- I did not as i couldnt get into the BIOS to change the Graphics, so if theres no beeps, i have a memory problem(the RAM being used is fully combatable with the Mobo)
its strange how it stops to keep checking the DVD drive and doesnt use the HDD once through starting up,
i thought it may be the BIOS battery being low charged or having need of replacement but as its brand new (and a replacement) i dont think it would as it did the exact same problem with the old Mobo.
Same Problem
Mar 14, 2009
-   I have proble meith my bios. when I open the pc it work a bip sound heraing and than "BIOS Auto-recovering..." than it put some point but I couldn't make anything it's go without my cable took off...-   amonra8000
Solution #1
posted on Oct 26, 2006
Somewhat Helpful)
sandrew
Rank: Wiz
Rating: 83%, 5933 votes
If there are no beeps at all on boot up it's a memory timing problem,
Go into bios in standard bios settings menu and disable 'Halt On All Errors' if it isnt already, this may show up the problem in the initial power on self test.
Comments:
Oct 26, 2006
- when you booted with on board graphics did you before hand change the primary graphics controller as onboard in the bios or is it still set at yor AGP card if you had one fitted previous.
But if no beeps(should be one then another not two together)still have a memory problem and wont even get to bios screen and monitor will go into power save mode.
Not all memory works with all boards.
The board must be working if it's checking your dvd drive etc
You can't just boot with cpu and ram as what can the pc look for if theres no hdd.
Was this helpful?
Yes
No
Solution #2
posted on Oct 03, 2008
Not Rated)
wojoeric
Rank: Apprentice
Rating: 95%, 3 votes
Could be a power supply problem try checking it with another power supply, or maybe its just a faulty motherboard :-/
Was this helpful?
Yes
No
Solution #3
posted on Sep 24, 2008
Not Rated)
mariolimonge
Rank: Apprentice
Rating: 0%, 0 votes
its the hard drive or maybe even the dvd rom, un plug the hard drive and try restart. if it botts then u know its the hard drive which is causing the problem. And same with dvd player. have fun
Was this helpful?
Yes
No
Solution #4
posted on May 26, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
reset the CMOS
Popular Solutions for Abit SG-80 Motherboard
Questions and Unsolved Problems for Abit SG-80 Motherboard
Do you recommend Abit SG-80 Motherboard?
Answer
Answer
my jetway v4mpmd onboard graphics has failed just a black screen appears. Originally had an FX5200... (More)
Answer
How do you install a performance chip on a 2003 audi a4 1.8t
Answer
heat trip switch melted
Answer
Hi i need a new motherboard model no W340UI and another model number on the same laptop MT3107b
Answer
asrock wolfdale 1333-d667 display color bars or display disappears after boot or will work for a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Abit SG-80 Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14846
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
