Question about Akai LCT3201AD 32 in. LCD Television
Akai lct3201ad - cost to repair vs. replace power supply
Looking for best place to buy new power supply, best place to have it replaced and cost for each.
thanks
  • Anonymous Dec 22, 2008
    This is my Problem to. How I can fixed this problem?
  • 35 Answers
Hi
I bought AKAI LCT3201AD power supply board chipper price $100.00 in ebay:
AKAI POWER SUUPLY BOARD LCT3201AD MLT169A
OR you can order by phone:
213 627 4071
Thanks
DS
Posted on Jan 03, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Lcd parts.com
Posted on Nov 10, 2008
Lct3201ad power supply - plz let me know how much
The AKAI LCT3201AD I got from a friend who didn't know it was stuck in stand by. Took it to the local TV repair guy who charged me $25 deposit to check it out and replaced the power supply for $99 total. Works good except for DVD player that won't eject. Just need to figure out what bolts are to be used for mounting to the wall.
Sep 02, 2010 | Akai LCT3201AD 32 in. LCD Television
Need power supply board for akai model lct32d do not know if same as lct3201ad ?
You can have more than one manufacturer of power supply for the same TV model, best thing to do is to actually get the printed numbers from the actual power supply to match it correctly.
Here are the parts for LCT3201AD, see if it looks right: http://www.shopjimmy.com/catalogsearch/result/index/?q=Akai+LCT3201AD+&limit=200
LT32D is not listed.
Dec 24, 2009 | Akai LCT3201AD 32 in. LCD Television
Akai LCT3201AD won't turn on. Plugged in and
you have a power supply problem there are caps in the power supply that fail the will be bulged on the top these have to be replaced in most cases or a fast switching diode
or get a replacment power supply and exchange it
Oct 24, 2009 | Akai LCT3201TD 32 in. LCD Television
My Akai LCT3201AD won't turn on
Normally the end model numbers signify a revision. Your LCD screen should work fine in the other one. Manufacture's tend to keep LCD screens within the same vendors for specific models for cheap replacements =)
Jan 22, 2009 | Akai LCT3201TD 32 in. LCD Television
MY AKAI LCT3201AD TURNS OFF BY ITSELF
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Jan 10, 2009 | Akai LCT3201AD 32 in. LCD Television
On off switch broken in akai 32" lcd
The power supply is defective and will need to be replace or repair since no new boards are being manufactured.
I repair these power supplies, write to jah2mil@hotmail.com if you require further information or assistance.
Dec 05, 2008 | Akai LCT3201AD 32 in. LCD Television
AKAI LCT3201AD
A very common problem with that unit is the power supply. You could probably open the rear case yourself and locate the power supply module. Look for the electrolytic caps EC18, 19, 20 all are 1000uf/16v Then EC9, 10 which is 1000uf/35v and EC14, 25 both 470uf/35v Replace these and you should resolve the problem. If you have some basic soldering experience and be patient it's not a difficult repair. Just make sure that you get the new cap placed in the same manner, they are polorized, having a positive and negative side.
You'll need some solder, desoldering braid and a GOOD soldering station or stick. Most of this, including the caps you can get at ACME sales in Florida.
Good Luck!
Bill
Oct 27, 2008 | Akai LCT2701AD Television
Power Shuts off after 30-45 minutes
I will say that the part that you bought could have been removed from another LCD and it might not be working properly due to components that become defective when they overheat.
It looks like there are not service parts or they are difficult to find.
Most power supplies I've repaired have components that failed after about 1500 hours of use.
The only way to get the LCD working is to repair the power supply to the component level instead of swapping it.
In about 95% of the time the power board is defective.
Let me know if you need further assistance.
Aug 16, 2008 | Akai LCT3201AD 32 in. LCD Television
AKAI LCT3201AD Tv will not stay on when you turn it on the light changes to green and then in about 10 seconds turns red again. TV is 1 1/2 years old. For awhile we were able to unplug it and plug it back...
I have just repaired one of these sets for the 2nd time. The problem is definitely the Capacitors on the Main Power Supply Board. If you are handy, you could replace them yourself, or You can send your board to me and I will make the repair for you. Akai initially used what I feel are sub-standard Capacitors on these boards, and I have found that by replacing most of them, this problem can be eliminated. My email address for repairs is Lakers4life42@yahoo.com
Mar 14, 2008 | Akai LCT3201AD 32 in. LCD Television
Power Supply burned up
I had a power supply issue with my TV too. I was able to repair it. But, during my research I cam across a store which does sale the power supply. The cost is $150 and can be purchase at fox international. Though it it is not listed on the online e-store, you can call and give them your TV model and let them know you are looking for a power supply board The web site is www.fox-international.com. Then click on the e-store link or call
1-800-321-6993.
Oct 06, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
501 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
