Question about Kicker KX Series 04KX1200.1 1200w RMS Monoblock Amplifier
Kicker kx1200 i have a kicker kx1200 running an arsenal 15 and one day it just stoped and when i got home i opened my trunk and i smelt something and iam thinking that it is a bad wire or something like that.oh yah it also has power to the amp and i also checked the fuse. plz need someones help to figure out the problem. thx..
  • tankass Nov 13, 2007
    I have a kicker kx 1200.1 and it is pushing two 12" kicker comp vr and it was working good for a day or two and then out of no where it cut off on me and everything is lite up fine green power light and everything but the is no power coming through the speaker wires i have changed my rca wires and all can somoene help me
  • maurice121 Dec 03, 2007
    im having very similiar problems mine just quit .no warning power light is on red kicker power light on top of amp is on fan is not working an i have know outputs.i dont here relay clicking on.the entire board has power except on the rca side of the board.please help. kicker kx1200.1 monoblock
I am having the same issue, my kicker kx 1200 watt amp was pushing two JL Audio W6 12's and amp has power but no speaker out put, sending my amp to kicker for the thrid time. I tryed in my friends car with no luck.
Posted on Sep 02, 2008
Something in my engine clicks on and off when my trunk is open and my dash lights flicker on and off in my 2001 430 CLK
Yes i have had this before its because you have connected the wires wrong and used the feed for the lights ,cannot tell you the colours as i cannot remember and iam colour blind but this is whats wrong your 12v switchable feed what you think is the feed from the ignition is actually your illumination feed for the radio ,if in doubt run a new wire from the ignition switch direct to teh radiop this will cure it i promise ,Sorry i cannot tell, you what wire is what but when the reds and greens all look the same ?? you understand my plight but this is your problem i do know for sure as done two motors like this in the last few years .
Jan 22, 2012 | 2001 Mercedes-Benz C-Class
Driving yesterday smelt something burning and my a/c stoped blowing cold air. now my a/c does not work , opened the hood somethin was smokin a little bit but im not sure what it is
Take a look at the accessory belt that drives the AC compressor. It sounds like the AC clutch seized and you were smoking the belt.
Jul 22, 2011 | 2005 Volkswagen Jetta
Subwoofers don't work
the voice coils are probably fried. you may want to check your amps to see if they are putting out dc voltage. you may be abel to find a place that can fix the subs. otherwise you will need to replace them.
May 06, 2010 | Sony 12" Single-Voice-Coil 4-Ohm Subwoofer
No power to my kicker ZX 1000.1
sounds like you blew a fuse for the battery power supply to the amplifier
Mar 23, 2010 | Kicker ZX10001 Car Audio Amplifier
My kicker kx1200 powers up fine but turns it self of an comes back any ideas to what it can be
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 25, 2010 | Kicker KX1200.1 Car Audio Amplifier
I have 2 kicker l7 12 dual voice coil subs.. i just friend a hifonics 1600w amp and am wondering if a kx 1200.1 kicker amp will be enough to power them they are 750w rms a piece .. can these be run at 1...
it all depends on the impendance of your subs if u have duel 4ohm or duel 2ohm, 2 duel 4ohm speakers can be wired at 1ohm to the amp, and with a kx1200.1 that would be pushin 2400 peak and 1200rms
if ya have 2 duel 2ohm speaker than you can only wire them to 2ohm and would be pushing 1200 peak and 600 rms with the kx1200, so if you have the duel 4ohm i would go with the kx1200.1 and if u have the duel 2ohm i would go with the hifoncs
Apr 23, 2009 | Kicker KX1200.1 Car Audio Amplifier
Trunk not open in 2000 corolla
have a helper lean down on it while you trip the lever. if it opens oil the heck out of the latches
Jul 24, 2017 | 2000 Toyota Corolla
Nedd help kicker kx1200
it should power them fine but you will have to make sure you do not wire them where the ohmn load is below what the amp is stable at most of the are 2ohmn stable you can use a mutimeter in the ohmns setting to determin this
Oct 31, 2008 | Kicker KX1200.1 Car Audio Amplifier
2004 vw beetle trunk problem
I had the same problem and I did the following:
- demount the plastic cover of the trunk (2 screws)
- locked and unlocked the trunk, while it was open to understand the system (it's really easy)
- lubricate all relevant parts
- checked the functionality
- put the plastic cover back on
- done
Overall it took me 15 min. It worked on my beetle. No guarantee. I'm not a technician.
Sep 13, 2008 | 2004 Volkswagen New Beetle Convertible
Kicker KX Series 04KX1200.1 1200w RMS Monoblock Amplifier Logo
277 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
