Question about Samsung HCN653W 65" Rear Projection Television
My TV is overlapping images and text, and there is a purple line at the top.
is there a solution for this.
    Genius:
  • 1,847 Answers
This seem to be convergence issue. did you try reset to factory setting from the menu?
Posted on Nov 11, 2008
  • Legin Varghese
    Legin Varghese Nov 11, 2008
    It sounds like you have some poor connections on the TV's convergence
    IC's.
    If you own a good soldering station / pencil.
    The convergence IC's will be located on the right hand side of the TV,
    looking from the back. They will be attached to a large silver device
    (heat sink). The IC's have 16 pins on each one, there 2 of them, side
    by side. Remove old solder and apply new.
    I hope this was helpful
    Thanks
    Kevin
    Genius:
  • 1,550 Answers
The problem is convergence in your tv .
  • SAM ANDERSON Nov 11, 2008
    Bad convergence . You need to replace it .
    You can get from the link below
    Convergence board
    Have you tried hard reset .Sometimes it may work .
    Unplug the power chord for 30 minutes and plug back the power supply to tv .
Text alignment in ms publisher 2010
how about not putting the image in the text box? make them separate objects so that they don't overlap.
Apr 15, 2013 | Microsoft Publisher 2010
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung lcd tv with double image on screen
T'Con board should be suspected. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Samsung LN46B610 46 HDTVReady LCD TV
Picture on my rear projection tv
This set needs alignment and convergence adjustment. If the set is quite old, it may be showing its age and can't be fixed.
Sep 08, 2012 | Sony KP-57WS510 57" Rear Projection HDTV
My HP 5880n TV has started showing purple lines everywhere. Particularly in images that should be shiny. Images of water are the worse and look almost all purple as each shiny part is surrounded by a thin...
I got some water between the 2 screens at the bottom of my HP 5880n. I took the screen out and separated the 2 screens at the bottom and wiped and let dry. I put it back together after it dried and put back in tv, now when it1s on it has a foot and a half circle that is clear as a bell and the rest looks blurred. is there a fix for it or do i have to replace. Where can I find a replacement, I looked on line and can not find any. Thx
Aug 18, 2010 | HP Md5880n 58 in. HDTV
Screen image overlaps edges of screen and entire image is not fitting the screen
if your tv has a format button on it just press it until your picture is to where you like it. plus if you have a hd reciever it also has a format setting on it to.
May 02, 2009 | Televison & Video
Purple and Green haze on television image
Do you have any speakers near the TV, that aren't shielded... ?That's kinda what it sounds like to me.
Apr 10, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Text/images overlap each other in 3 colors, 3D distorted picture
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Double image is printed on one page, overlapped on Brother 7225
It sounds like a piece of paper is wrapped around the fuser roller. Look in the rear of the machine with a flashlight.
Jan 22, 2009 | Brother MFC-7225N All-In-One Laser Printer
Double image on green
Focus won't help if it is a double image. Sounds like convergence amps need to be replaced. Very typical on these.
Jul 04, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
29 people viewed this question
Jerry Greenberg
Jerry Greenberg
