Question about Onkyo TX-SR803 Receiver
Ps3 and onkyo receiver
I have my ps3 plugged into my onkyo 705 receiver with an hdmi cord and i get sound, but no video.
I have tried an optical cord going from the ps3 to the receiver with the an the hdmi going from the ps3 to the tv, then i get the video but no sound
Hello.
I have a similar setup and am having problems of my own, but i've got it somewhat working at the moment.
I have the TV connected via HDMI to the receivers HDMI output port.
I have the PS3 connected via HDMI to the receivers HDMI input port 1.
I went on the receiver and followed the instructions in the manual to setup the DVD function on the receiver (i chose to call my ps3 a dvd) to use HDMI-1. I can't remember the button combination as i'm not at my hosue right now, but it was in the HDMI section of the manual (page 44 on my manual). Essentially I had to tell the receiver to enable HDMI for the DVD function rather than being defaulted to "No". At that point, with the default ps3 setup, I was able to get video to pass through.
Next, i went into the video options on the ps3 and changed it to 1080p (since my tv supports that).
Where I"m having my problem is that the sound from the ps3 outputs directly to the TV and doesn't output on my receiver for some reason.
How I've rigged that to work is to take the HDMI to RCA cable that came with my PS3 and i plugged in the Red and White wires on the back of the receiver in the DVD section of inputs. At that point the sound comes through the receiver.
What I don't know how to do and would really like to know is how to get the sound to output on my receiver via HDMI only and not with the extra cable.
Anyway, if i'm making sense above and you follow that, you should be up and running (but maybe not in an optimal configuration).
Let me know if you ahve any questions.
Also, if anyone knows the solution to my issue, i'm all ears.
Thanks.
Posted on Nov 15, 2008
Ps3 doesnt give out a surround sound output
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Hi i can't get any sound thru my speakers. I have hdmi from ps3 to tv optical from ps3 to receiver. i have tried dvd video 1 video 2 what setting am i missing? thanks
first: make sure you have the audio output setting on the ps3 set to digital optical output
second: make sure you select whatever the optical input is assigned as, probably dvd. i think there is a button on the front of the receiver that says digital input, make sure you hit that. A little light on the front screen of the receiver will say digital.
May 09, 2010 | Onkyo TX-SR503 Receiver
Separate video and sound on hdmi
yes it would be possible to separate audio and video from your PS3. You would need to go to the PS3 setting for audio and choose Optical instead of HDMI. You would need to connect and Optical cable from the PS3 to the receiver. Then on the receiver you would need to set the digital inut for your source(PS3) to optical.
Mar 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
No audio from my PS3 through the Onkyo 5100 7.1
if you are using an HDMI cable dont expect sound to come out (even thought HDMI carries both audio and video) the onkyo HT-s5100's Receiver is the HT-r560. the 500 models of the onkyo receiver does not allow HDMI to carry both audio and video. it only allows the video signal to pass to the receiver.
if youre using optical for audio w/c is what you need then these are the steps you need to follow.
*first make sure that the optical connections are ok at the back of the receiver.
*make sure that your DIGITAL INPUT is set to either OPT1 or OPT2 whichever optical input you used to connect the optical cable.
*then go to your PS# settings : go to sound settings / audio moutput settings/ select digital out (optical).
then enjoy.....ü
Jan 27, 2009 | Onkyo HT-S5100 Theater System
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
No sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
Jan 10, 2009 | Onkyo HT-SR800 System
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Connecting a Dish 622 Receiver to the HTR500 and a Sony HDTV TV
I haven't researched to actual manuals for your equipment, but I'm guessing that the optical may be disabled when the HDMI is used. You could try using the component video outputs to the TV and then the optical to the Onkyo.
Jan 02, 2008 | Onkyo HTR500 Receiver
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Onkyo 705
You have probably done this, but have you changed the video settings in the setup menu to have the tv using HDMI out? I believe it is under the first option when the menu comes up.
Dec 23, 2007 | Onkyo TX-SR803 Receiver
Onkyo TX-SR803 Receiver Logo
774 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
