Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
42H82 Picture is ALL GREEN
Really simple problem. Picture is COMPLETELY GREEN. Turn on the TV and you see nothing but green. Determined it is NOT a gun problem. Been looking at the hyper board and suspect the problem is there. Any solutions?
    Sergeant:
  • 337 Answers
If the picture is all green and does not shutdown then is probably not the tube and you need to check the green output transistor witch is ussually located in the crt board in the neck of the green tube,you also have an IC that gives the colors then you have a driver and finally the output,(IC and driver rarely go bad but is possible),when you pull the board out of the tube make sure it comes out easy,do not twist the board because it might brake the pins in the tube(gun) and then we will have big problems, many times they secure the board to the tube with silicone and it needs to be removed or cut before the board will come out.Each gun has an output and the defective one should be replaced with an exact replacement.Check also the conections in the green crt board.Let us know if you need more information.
Posted on Oct 26, 2006
  • Omar Urrutia
    Omar Urrutia Oct 26, 2006
    Your rating response is also important.
11yr old "tube" tv has a completely green picture for about 10 minutes, then back to normal. Back to green after an hour or so. Can it be fixed?
you have to get the 'tubes' replaced with new ones, can be done at service.
the tubes of colors green and blue are getting old, so they cant withhold that much energy while being this old
Apr 18, 2013 | Sanyo Televison & Video
TV picture turned green, then it went out completely
if your set went all green then shut off you might have a shorted anode on the green tube this is not good news if the set went dead then it probably killed your power supply you will have to get this fixeed first then check to see if tube went bad.i need model of your set ill help yo find out k
Dec 27, 2007 | Televison & Video
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
Green bowed bands
replace convergence ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 27, 2007 | Toshiba 57H82 57" Rear Projection...
Green flashing screen
Dec 26, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 42H82 RPTV: Sound but no picture
It sounds like the 200v supply to the crt's is missing. this is the source for driving the tubes, other than the high voltage generated by the flyback transformer. If the set got really bright gray with wome white lines that are kinda on a diagonal, this is generally the cause. the source for this voltage is a diode on the secondary of the flyback transformer.
Jul 11, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
