Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Ice maker jamming up...
I have a maytag side by side, the ice maker is producing partial pieces of ice. They are not solid cubes. When the ice maker goes to release the ice, the ice gets stuck and will not fall in the bin. It makes a snoring noise.. Almost like its turning to make more ice, but the piece of ice that is jammed in there will not allow it. What can I do to fix this problem?
    Problem Solver:
  • 6 Answers
I had a similar problem. I cured mine when I increased the water pressure to the ice maker. I had been using the output of my reverse osmosis unit to provide water and the pressure was too low. I added air to the bladder of the water storage tank to the max allowed by the RO manufacturer. I rarely have a problem any more.
Hope this helps,
Glenn
Posted on Nov 09, 2008
Ice maker quit making Ice cubes
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | Maytag MFC2061HES Stainless Steel French...
Ice maker quit producing ice, cubes were not solid before,either.
shelling:
Jan 01, 2010 | Frigidaire Refrigerators
Ice maker crushes ice even in the cube mode
Remove the ice bin . Press the door switch in , and press the dispensor actuator pad . In the back , on the panel with the prongs , there is a square box cut-out , which houses a white square plastic piece . If this piece doesn't lift when set on cubes , then the solenoid is bad or a wire has come off of the solenoid . To access this solenoid , remove the 3 or 4 screws holding the panel on . Also try lifting this plastic piece with your finger , to see if it is frozen . Also a sign that the cube solenoid needs to be replaced .
Oct 31, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
My ice maker is letting too much water go into the ice tray so it freezes in a solid piece. Cubes do fall down but there is so much water it freezes into a solid block
The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Oct 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Will not dispence ice, crushed or solid cubes, will dispence h2o
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
and if the ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 09, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
Ice maker is making ice but the ice is becoming solid in the tray and jamming the blades and not comimg out in cubes
THE POSSIBLE CAUSES MAY BE FROM THE CUBE SIZE CONTROL
ADJUST THE CUBE SIZE CONTROL
INSPECT THE WATER SUPPLY LINE
TEST THE WATER INLET SWITCH
TEST THE WATER INLET VALVE
Sep 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
274 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
