Question about Toshiba Computers & Internet
My laptop can no longer connect to the internet, the ipv4 address is gone.
  • kindashy69 Nov 09, 2008
    we have tried both wired and wireless and no internet, we r using steamstream 6520 modem. we have spoke to the techs at toshiba and they say its the service provider and the service provider says its the computer!! soo frustrated!! the computer cannot pick up the modems signal and the ip address we do have is not a good one! it starts with 169 and supposed to be 192.
  • Jannette Amandy May 11, 2010
    How do you connect the laptop to the Internet? Is wired or wireless?
    Do you have a router?
    If your laptop is connected to the modem, is Internet working?
    Scholar:
  • 132 Answers
If your laptop is directly connected to the steamstream 6520 modem do you have Internet or no? Who is your Internet service provider?
Posted on Nov 10, 2008
I have been having issues with my internet connectivity for a while - its been fix after fix and i feel like im slowly fixing the problem but adding more onto it. The exact problem from the top - Spee
Problem is that ipv4 config.
For any computer on a home network an automatic IP-address is handy. So the ipv4 config should be set to DHCP.
But then there should be a router that hands out IP-addresses and the IP adress of this router should be given in the ipv4 config as Standard gateway.
That is for home, but to resolve internet adresses your computer needs DNS, you can use common dns servers, or the ones given by your internet provider.
Fill these in under DNS in the config.
Aug 23, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
No internet access
Check the IP configuration for the network adapter. Make sure in properties for IPV4 it is setup to automatically get IP address and automatic DNS
Aug 20, 2012 | Dell Computers & Internet
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
GETCE6B1, Internet Protocol Version 6 Not Available
The 'IPV4' (Internet Protocol Version 4) was designed for a world with 4 billion unique devices (desktops, laptops, netbooks, iPod Touch/Phone, IP-TV, cell-phones, et cetera).
That limit is being reached!
The newer 'IPV6' (Internet Protocol Version 6) was designed to give a unique IPV6 address for EVERY SQUARE INCH of surface of our planet.
So, if your computer is "talking" to an IPV6 device (router or modem), you should _NOT_ get "IPV6 not available". However, if your computer is "talking" using IPV4, you probably _WILL_ get the IPV6 not available" message.
No big deal. If your computer cannot "talk" IPV6, then it should "talk" IPV4.
Jan 18, 2011 | Sylvania G-Netbook
What is ... '' Teredo Tunneling Pseudo-Interface , something to do with IPv6 as part of networking ??
Teredo is an IPv6 transition technology that provides address assignment and host-to-host automatic tunneling for unicast IPv6 traffic when IPv6/IPv4 hosts are located behind one or multiple IPv4 network address translators (NATs). To traverse IPv4 NATs, IPv6 packets are sent as IPv4-based User Datagram Protocol (UDP) messages. This article provides an overview of Teredo—including Teredo addresses and packet structures—and detailed explanations of how communication is initiated between Teredo clients, Teredo host-specific relays, and IPv6-only hosts using the IPv4 Internet, the IPv6 Internet, Teredo servers, and Teredo relays.
more at http://technet.microsoft.com/en-us/network/cc917486.aspx
Dec 31, 2009 | Computers & Internet
Wireless router problems
your computer is only connected to the signal coming from the router that's why it's saying connected but it seems that your router is not properly configured to provide internet access since your dns server is the same as your default gaetway. it could be that the your router is not in sync with the modem.
- if it's working before, tyr to power cycle everything by turning all the devices off then turn on the modem first, wait for all the lights on the modem to turn on then power on the router and the computer.
- if the router is for initial setup, kindly provide me you ISP, brand and model of the modem and how you connect the modem to the router and tell me if how you access the internet directly from the modem.
Jul 02, 2008 | D-Link 802.11g Wireless Router WBR-1310...
WR850 Install Problem on new VAIO Laptop with VIsta
try to change your OS! frfom VISTA to XP. because sometimes the problem is in not the router rather the problem is, conflict bet. IPv6 and IPv4.
Apr 01, 2008 | Arris WR850G Router (DHWR850G)
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
