Question about IOGear MiniView 4-port KVM Switch
Can't Use Wireless Mouse
This KVM switch doesn't allow you to use a wireless mouse. I have tried several. Even one that has a PS2 connector with a wireless transmitter. I contacted IO Gear, and they said the only solution was to buy the more expensive USB KVM. I've been looking for a PS2 adapter that will allow you to plug in a wireless USB transmitter, but no success so far. So, if you want to be able to use a wireless mouse with this KVM, then don't buy it. If you know of any adapters that will allow this, please post a solution.
  • 624 Answers
I?ve had issues with USB mice on the more inexpensive KVM switches. I?m currently using a Belkin OmniView using a Microsoft Explorer USB optical mouse and a PS2 to USB adaptor. The adaptors I use are from Cyberguys.com and work well for most of the USB mice we have.
Posted on Jul 18, 2007
Kvm switch is not detecting my g5 mouse , tried diff ports and tried alternating keyboard and mouse. think the switch has gone bad
this is not uncommon. many kvm switches cannot work with those types of wireless mice. the reason for this is due to connection codes. these mice require a connection to secure the use with each computer. you can attempt to do this with your setpoint software. located in C:\Program Files\Logitech\SetPointP you will find the program CONNECT.EXE
run this to redo your mouse connection. i will however inform you that even if this works there is a large chance that upon switching to the next pc the mouse wont work and you will need to repeat this process with each pc switch everytime you toggle pcs.
rule of thumb. if the mouse is wireless don't use it with a kvm.
Jun 29, 2011 | IOGear GCS632U 2-port KVM Switch
My keyboard is typing double letters. I have rebooted, changed batteries. But still typing double. reverted to usb keyboard for time being
I had this problem after changing the batteries in Logitech Cordless Internet Pro Keyboard - Model Y-RAJ56A, very frustrating.
I am using a KVM switch that only has PS2 outputs and one of the computers doesn't have PS2 connectors for both keyboard and mouse. This necessitated another mouse & receiver. Receiver will accept both mouse & keyboard but initial installation didn't include pairing the KB with the receiver, it
picked it up from the KVM.
When I changed the batteries in the keyboard I instinctively pushed the buttons to pair the receiver to the keyboard.
Wrong move!
Now the computer is receiving keyboard command from both the former 'mouse only' receiver & the KVM, creating ddoouubbllee letters. After pairing, they refused to be unpaired.
Solution was to go to Control Panel, in Device Management and disable Wireless Keyboard. Now it only receives keystrokes from the KVM.
Problem was solved.
Hope this helps, Plasticman69
Sep 24, 2010 | Logitech Alto Cordless Laptop...
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
Belkin 2-Port KVM Switch
It is compatible with a wireless mouse, as long as it is a PS2 mouse.  if it is USB you could try using a converter, but it may not work.
Nov 04, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
Ps2 mouse not working on one system
Try and use only USB or only PS2 mouse for the same.
Oct 19, 2007 | Inland 08216 2-port KVM Switch
KVM GCS1734 with microsoft wireless mouse/keybrd 4000
The MS keyboard & mouse receiver is effectively a USB hub with two devices connected to it. So, plugging it into the keyboard socket on the KVM switch may well work, depending on how that particular switch implements USB. If it just passes things through, it should be OK. On the PC side you should only need to plug in the USB cable from the switch's keyboard port.
Sep 30, 2007 | IOGear USB gcs1734 4-port KVM Switch
Wireless keyboard doesnt work with switch
once you have switched pc you will need to re-sync the wireless keyboard and mouse with the new pc, because although you have switched pc the keyboard and mouse do not know this. there should be a reset/resync button on the bottom of both the keyboard and mouse
Jul 30, 2007 | D-Link DKVM-2K 2-port KVM Switch
KVM switch mouse trouble
Does a mouse work if plugged directly into the laptop? Sometimes you have to change a laptop in the BIOS to allow a PS2 mouse in addition or instead of the touchpad. It may not be recognizing the KVM as a mouse. Try plugging the mouse right into the laptop and see if that works.
Mar 24, 2007 | Belkin F1DK102P 2-port KVM Switch
Problem with Belkin OmniView KVM F1DS102P
Is the LED for position 1 and 2 always on? If the switch doesn't detect power on the PS2 keyboard connector it won't let you switch to to that position. If you are using a USB mouse with an adaptor or a wireless mouse try a conventional PS2. I have a MS wireless mouse one of my switches does not like and have to resort to that sometimes. Another issue could be excessive cable length or PS2 extension cables. Let us know if you have any more questions on this topic and please don?t forget to rate the post.
Aug 31, 2006 | Belkin OmniView¿ SOHO Series 2-Port...
IOGear MiniView 4-port KVM Switch Logo
167 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
