Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Kenmore Elite HE4t cycle time blinking but nothing happening
Firtst I had a F/2 code flashing. Checked the hose to see if there was any clogging. There was none. Tried to run the cycle again. It filled up with water again and then it stopped again and gave me the F/2 code again. I then unpluged the washer for about 5min. Plugged it back in and then tried running again. The code went away but now the door is in the locked position and now the cycle time is flashing. No matter what cycle I put it in the minutes flash and the door is locked. It won't let me do anything. Any help would be greatly appreciated.Thanks!
  • twosell4u Nov 10, 2008
    Awesome!!! Problem fixed. My duaghters little sock was the issue in the pump. Thanks alot for your help!!!!
    Genius:
  • 1,028 Answers
Remove lower panel reach up to lock area and pull down on tab to release door remove as much water as possible go back to bottom and turn pump clean out to left HAVE PLENTY OF TOWELS HANDY..clean pump trap out and reinstall
Posted on Nov 10, 2008
We have a Kenmore Elite hE4t front loading washer and now it keeps flashing FH code. We have followed all the troubleshooting suggestions - checked water faucets, checked inlet hoses for clogs, no kinks...
check the mesh on your water inlet valve. could be a problem with the valve or the pressure switch.
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
•Verify there is not a siphon problem
•Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
•Check all hoses for possible leaks
•Verify pressure switch operation
•Verify flow meter operation
•Verify CCU operation
Feb 13, 2011 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I have a kenmore elite he4t that stiops washing mid-cycle and keeps flashing and f2 error
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 11, 2010 | Kenmore Elite 45986 Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Machine stops at Mid Cycle and the Timer Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
Jan 25, 2008 | Kenmore Elite 45986 Front Load Washer
Help! Washer making noise but nothing is happening
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. To open door, press "end of cycle", wait for 2 minutes or till you hear distinct click; do not force door.
Rate me pl.....if helped.
Dec 28, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4T washer
Get the same code 2 minutes into cicle. F H
Nov 03, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
124 people viewed this question
Dan Webster
Dan Webster
Sal De
