HP C5240 won't scan and e-mail pictures
My HP C5240 keeps giving me an error message when I try to scan a picture and send to an e-mail recipient. The error message states that it is not connected to my pc yet I can print from my computer. I have reloaded the driver software but still will not work
SOURCE: DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
YES YES YES
i plug the damn thing and it will work
Posted on May 23, 2008
leroyal
  • 2120 Answers
SOURCE: Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Posted on Jan 25, 2009
  • 3 Answers
SOURCE: HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Posted on Feb 04, 2009
GoTechNinja
  • 12 Answers
SOURCE: software loads but HP solution center won't open
I would recommend un installing "any" HP software first, then download and install the latest driver from HPs site. You could could also try running the installer with all startup apps disabled incase there is some conflicting software. You can do this by typing in "msconfig" from start > run. Once open select "selective startup" then uncheck "load startup items". If you resort to this be sure you have unintstalled all HP software first as some HP software does run at startup. Also be sure to re-enable the startup items after troubleshooting.
Posted on Apr 15, 2009
  • 105 Answers
SOURCE: unable to communicate with HP scanning software
This happened to me a couple times with the HP Series all in one and stand alone scanners. Goto Walmart and buy a USB hub that has a dedicated power supply. For some reason HP is notorious for this problem.
Posted on Oct 17, 2009
How do I send multiple scans in one email?
place all scans in a folder the send the folder to e-mail recipient
to do that right click on the folder you create and a drop box will open
in that box will be a --send to --and you will see mail recipient
click on that and an e-mail will open with the folder as an attachment
put in the e-mail address and subject heading
type any message you wnt in the body of the e-mail and send
Nov 12, 2015 | HP PHOTOSMART 7520 E-ALL-IN-ONE
My windows 7 does not allow me to send pictures via e-mail ?
What error? Describe it (the exact text in the window) and/or include an image.
If R/C means right-click, and you're picking Send To then Mail recipient, if I'm not mistaken that opens up an email client's send-to window. Do you have an email client (like Outlook) installed?
Feb 03, 2015 | Computers & Internet
Windows mail problems
one way around is to open a new folder on desktop then transfer/save the pictures to that folder
having done that click on the folder then send to e-mail recipient
that opens up a new e-mail with the folder as an attachment and type in the new e-mail address then send
the problem is that if the photos are in the body of the e-mail when forwarding on, the format of the pictures is not reproduced as in the original message
Mar 09, 2017 | Computers & Internet
How to scan passport photo
How to scan a document or picture using Windows PAINT
Turn your printer/scanner on!
Click START
type PAINT
click PAINT under programs at top
untitled-paint window opens
in top left corner click the little white arrow
click FROM SCANNER OR CAMERA
choose settings you require
click preview (scanner may have to warm up for 20 seconds)
preview appears in window
adjust edges if need be (click/hold/drag)
click SCAN
item appears in Paint
ckick the white arrow again and choose SAVE AS, give it a name and click SAVE (it will automatically save it to PICTURES)
you can now RESIZE or ROTATE the scan
you can also add text to it by clicking the letter A and drawing a box on the scan
If you want to email it, just close Paint, go to PICTURES, right-click on the scan and choose SEND TO then MAIL RECIPIENT
Aug 26, 2011 | HP Officejet 4355 All-In-One InkJet...
I keep getting the following when opening or sending mail: The message could not be sent. The setting for your outgoing email [SMTP] server might need to be configured. To find the server settings for...
Quick summary:
It appears that email address does not exist - which is why your email program was unable to send the message. There may be a small typographical error in the address - which you would need to correct in order to send the message successfully.
Background:
The error message you received says the "domain does not resolve". That means your outgoing server (which is used for sending messages) couldn't find the information about the recipient's address -- and more specifically, the "domain" of the recipient's address. (That's the portion of an email address following the "@" sign.)
The error message indicates the domain of the recipient's address is "quickfireprocuctions.com". But a quick check of domain registration records indicates there is no registered domain by that name. And if a domain is not registered, there can't be any websites or email addresses which use that domain name.
However, there is a properly registered domain "quickfireproductions.com" (with a "d" rather than a "c"). That seems much more likely - as the combination of recognizable words ("quick" "fire" "productions"). That domain is registered to owners in Florida, USA. See details at: http://whois.domaintools.com/quickfireproductions.com
Solution:
If that registered domain name sounds right, then you should revise the email address in your message to use the correct domain name (i.e., replacing the "c" with a "d").
Feb 23, 2011 | Microsoft Windows Live Mail
How to scan a picture & email it?
Using MS Word go to Inseert --> Picture From Scanner or Camera
Scan the image from there
Once you have scanned the image go to File --> Send To Mail Recipient (As Attatchment)
Then send it as a normal E-Mail
Your scanned image will be sent as an attatchment
Feb 23, 2011 | HP OfficeJet J4580 All-In-One Laser...
How do I email photos from my dell computer?
A simple process to e-mail photos from any computer using windows is fairly simple. Find the folder with the pictures in them. Then select the pictures you would like to send by pressing the "ctrl" key while left clicking(left mouse button) on each picture you would like to send. Once you have selected the pictures then right click on one of the highlighted pictures and select "send to" and then "e-mail recipient" and then right click. This will bring up a page to send the e-mail using your default e-mail program with the pictures attached. You can then add any remarks,comments ect. and choose who you would like to send the pictures to.
Nov 25, 2009 | Dell Dimension 2400 PC Desktop
How to send a photo from " my pictures "
  1. Open internet explorer
  2. click on tools
  3. click on internet options
  4. click on programs
  5. select outlook as email client
I have selected my e-mail client YAHOO MAIL
May 08, 2008 | HP Pavilion Media Center TV m7350n...
Recipient Barred
TRY RENEWING PROXY SERVER FOR MEDIA NET. THIS SHOULD CORRECT THE MMS PROBLEM....
Feb 23, 2008 | HTC TyTN Smartphone
E-mail pictures using Kodak EasyShare software
when I send a picture, the envelope shows sending but it never goes thru to the recipient.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
161 people viewed this question
jasbo
jasbo
