Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Programming my keyless entry
I purchased a chamberlain keyless entry (wireless) for my Genie garage door opener...following instructions...when i push the learn button it blinks right away and supposed to have a steady light until its programed...maybe purchased the wrong wireless
  • aleb200 Jan 02, 2009
    thank you so much, already purchased a Genie and is working great
    Sniper:
  • 98 Answers
Yes, you purchased the wrong wireless. You must get a Genie keyless and there are two types of Genie keyless (GWKP & GWK-BL) depending on which Genie operator you have. You might think about a wired keyless entry (Domino GD-1). Then if you change your operator you don't have to change your keyless.
Posted on Jan 02, 2009
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener, of which I tried to program a new remote. but it did not program. in the event I accidently errased my keypad password. How can I reprogram the keypad, i cannot...
Hello there,
It actually depends on what you are trying to program. And these instructions apply only to openers that do not have dip switches on them.
Remotes: push don't hold the colored learn code button all models have different colors. After pushing the button hold the remote behind your back and push it three times. On the third time the door should run.
Keyless Entry: Program the code you want into the keyless. Push the colored learn code button and then enter the code and push enter three times slowly. on the third time the door should run.
Home-Link. Hold the two outer buttons until the blinking pattern changes. Then hold the button you wish to program and point and click your remote at it. Push the colored learn code button and push the homelink button three times.
There are two models of the Wireless Keyless Entry System, the 740CB and the 940CB. The 940CB is for use only with Security+® garage door openers having an orange/red smart/learn button. The 740CB will work with all openers manufactured since 1990 that have a yellow, white, gray, or green smart/learn button. It will not work with Security+® openers.
To program the keyless entry, first locate the smart/learn button. On our chain drive models, this button is on the end farthest from the door. On our belt and screw drive models, it is on the right side as you face the door from the opener. You simply press and release the smart/learn button. You now have 30 seconds to enter your four digit PIN number into the keypad and hold the enter button for five seconds. Wait one minute and test the keyless entry by entering your four-digit PIN number and pressing enter.
With some Security+® models, you can also program your Model 940CB Wireless Keyless Entry without climbing a ladder, right from your Multi-Function Control Panel. Simply enter your pre-selected code and press and hold the enter button on your Keyless Entry. Then press and hold the light button and the pushbutton on your Multi-Function Control Panel. The garage door opener lights will flash to confirm that the Keyless Entry has been successfully programmed.
Hope this helped you solve the problem. All the best my dear friend. Elect_Comp
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
Have a clicker keyless entry with 4 diget code from old opener. klik2 and have new chamblerlin opener model 248735s want to program clicker to open garage door opener need instrustions i can print up
Often times, keypads and remotes are not compatible with newer models, even with the same manufacturer. If you are still interested in finding an instruction manual, try the Chamberlain website. You can also purchase a Universal Keypad, which will work with most models.
Mar 01, 2011 | Chamberlain Klik2u Universal Wireless...
How to program garage opener
SORRY,
Chamberlain key pads won't work with a genie receiver.
You will need to echange it for a Genie brand.
Also be sure what frequency your Genie is - They have changed the frequency a couple of years ago.
Jun 30, 2010 | Chamberlain 740CB Wireless Keyless Entry...
Can't reprogram/operate keyless entry pad for Craftsman Model 139.53661SRT3 garage door opener.
If the following instructions don't work and you have a good battery the keypad has failed.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Apr 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do i program this?
look at this link it should help.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A1400.pdf
or
push the learn button on the garage door opener then you have 30 seconds to go back to the keypad and enter your 4 digit code, last is to push and hold the ENTER button. do this until the garage door lite blink or you hear two click sounds.
Apr 01, 2010 | Chamberlain 740CB Wireless Keyless Entry...
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
536 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
