Question about Pioneer DVR-720 DVD Player/HDD Recorder
DVR-720 power off
My pioneer DVR-720 sometimes turns off (from "stand by") by itself completely and cannot be turned on again.
Only if I wait for about half an hour and plug off and on all the connections (2 x SCART, 2x antenna, 1 x power supply) it will turn to "stand by" again.
Any ideas what is wrong with it?
  • Anonymous Jan 03, 2009
    Hello.
    I also have the same problem as you.
    I am an electronics engineer and I did not find.
    You found a solution
    Thank you
    My MP address: leon.nicolas--@-laposte.net
    To remove "-"
  • robcurrie Jan 15, 2009
    Pioneer DVR 720H powers off by itself after a timer recording and will not swith on again. I remove the power cable for a few minutes, plug it in and am then able to power on again. It has happened 3 times now, apparently only after it is left on recording.
I have a solution to power it on again quickly. Unplug the power cable, short out the pins in the power socket in the back of the machine ( NOT THE POWER CABLE ) and plug the power cable back in - it should go into standby mode immediately. I think the problem is caused by a capacitor on the power supply board going faulty with age. I have not had time to open the machine to check yet, but I will do so soon.
Posted on Feb 25, 2009
Bonjour.
J'ai également le même problème que vous.
Je suis électronicien et je n'ai pas trouvé.
Avez-vous trouvé une solution
Merci
Mon adresse MP : leon.nicolas--@-laposte.net
Enlever les "-"
Posted on Jan 03, 2009
How to do hard reset for nokia lumia 720
#Option 1, Hard Reset NOKIA LUMIA 720 with software menu:
  1. Turn on the NOKIA LUMIA 720
  2. Go to Menu Setting > Setting
  3. Choose About and choose Reset your phone
#Option 2, Hard Reset NOKIA LUMIA 720 with Hardware Key Button:
  1. Turn off NOKIA LUMIA 720
  2. Press and hold together Volume Down Button + Power Button until LCD show exclamation mark icon
  3. Now release all number 2 buttons.
  4. Press one by one continuously:
    1. Press and Release Volume Up Button
    2. Press and Release Volume Down Button
    3. Press and Release Power Button
    4. Press and Release Volume Down Down
  5. If the step finish, the NOKIA LUMIA 720 will do the hard reset or factory format by itself.
  6. Wait until it finish to format, then we will need to setup like new again.
Aug 20, 2013 | Nokia Lumia 720 Windows Phone Black
My 720 dvr turns itself off and can only be turned back on by unplugging it from the power source?? Whats the issue here?
Thank you for waiting, your problem is commonly caused of leaky filter electrolytic capacitor in the power supply section, it will affect the regulation of the supply and sometimes need a little warmp up to back from functioning. The symptom will get worst if didn't replace the capacitor. Once isolated your unit will back to normal again.
Hope it may help you.
Give a thumbs if you find it useful.
Have a nice day!
Feb 09, 2011 | Pioneer DVR-720 DVD Player/HDD Recorder
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
Power off after recording
Hi All,
This is a power supply problem.... the MR2920 stanby IC miss behaved, it power off and fail to power back on.
Solution, get pioneer power supply replacement or take the dvd recorder to your local electronic service repair to take a look at the power supply circuit.
Best of luck
Kenny
Apr 21, 2009 | Pioneer DVR-520H DVD Recorder
Pioneer SD-P6091 Projection TV - TV turns off by itself
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jan 20, 2009 | Pioneer SD-P6091K TV
Pioneer elite pro 100
My set is doing the same thing again. The last time I fixed this (4 years ago) it was a capacitor gone bad in the power supply for the 24v standby circuit. (C166)
The service manuals can be ordered directly from Pioneer Part Number ARP3014 for Pro-100 model.
Apr 10, 2008 | Pioneer PRO-100 TV
Unlock Pioneer DVR-531H
check ebay - i got a disc for my 530h on there which unlocked it perfectly
Mar 30, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Pioneer dvr 112d power calibration error
updated firmware will not help. this is a known issue with Pioneer DVR-112D, drive needs to be replaced. Contact Pioneer for a free replacement, here is the url http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Notice+Regarding+CD+Read+and+Write+Functionality+in+Certain+Pioneer+Computer+Drive+Models
The issue occurs only under limited environmental and use conditions that are not typical for most end users, so Pioneer anticipates that most users will not be affected. If you are not experiencing any issues currently, there is no need to take immediate action. The service issue does not pose any health or safety risk.
Pioneer is aware of a potential issue with the above drives’ CD (not DVD) read/write capability. Under certain environmental and heavy use conditions, the above drives may become unable to read or write to CDs. To address this issue, for any of the above model drives that become unable to read and/or write to CDs, Pioneer will provide a replacement unit (which may be a newer model number) at no extra charge, shipping prepaid, subject to the terms and conditions of Pioneer’s standard limited warranty(excluding duration).
Again, we anticipate that most drives will not be affected. However, if your DVR-1810, DVR-2810, DVR-X122, DVR-112D, DVR-112DBK, or DVR-112DSV drive becomes unable to read or write to CDs, please contact Pioneer Customer Service by one of the following methods:
Complete an online replacement request form and submit it online. Once your model and serial number are validated, you will print out the completed form to mail along with the affected drive.
This online form is for United States customers only. For Canadian residents, please contact Pioneer Electronics of Canada customer service directly at 877-283-5901.
Mar 07, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Loses power after timer recording
Hi Saturn et al,
I had similar issues with my Pioneer DVR-520H. It completely went off for quite a while when it should be going to standby after a timer session. At the start it would come good after a few days. Eventually it went off altogether and nothing would bring it back.
With my father-in-law being an electronics person we investigated with the help of the service manual which I found on the net. The finger was duly pointed at the power IC (MR2920) on the power supply board (Pioneer will sell only the complete board). I ordered the IC from the UK (nikko-electronics.co.uk) GBP8.99 which was the only place I could find it online and soldered it in myself (easy, if you can solder).
All fixed and working again.
Hope this helps.
Apr 25, 2007 | Pioneer DVR-520H DVD Recorder
Pioneer DVR-720 DVD Player/HDD Recorder Logo
267 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
