Poulan Pro PR550N22SH 22Inch Briggs  Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) () Logo
Posted on Mar 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Poulan won't start
Anonymous
Level 3:
Brigadier General:
  • Master 6,468 Answers
  • Posted on Apr 01, 2012
Anonymous
Master
Level 3:
Brigadier General:
Answers
6468
Questions
0
Helped
2133940
Points
13357
Check for spark then try carb cleaner behind the air filter
Poulan HD145H42 won't go forward very fast
You seem to have a gearcase issue...like it's stuck in 1st. Have it checked by an equipment repair center.
1helpful
Poulan xt mower won't start
check the safety switches
Lawnmower stored for a year tipped up and all oil leaked out -- Won't start now.
You have most likely gotten oil on the coil, You need to remove the pull start assembly and you will see the coil/flywheel, check for any oil contamination which you can clean up with brake/carb cleaner.
1helpful
Runs but the chain won't move? Poulan
This sounds loke the chainbrake has activated, grab the hand guard and pull it fimly fully back to the top handle until it clicks and the brake is of, now try again.
2answers
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
My poulan pro leafblower won't start, feels like there's no compression
Check that the spark plug is snug. If that is not it, then you should check the tightness of the head bolts. Sometimes they loosen. After that it could be a blown head gasket or a stuck valve.
I have a brand new battery in my Poulan garden tractor. When trying to start, the flywheel will go around slowly and try to start but won't fully crank. When I put a battery charger on the battery it...
Bad battery, I know that you said that you have a new battery, try to borrow one from a neighbor and test it. Yours could be insufficient in cranking amps or your battery is bad. I have had a battery that would show the proper voltage, but as it had aged the cranking amps had fallen off and it could not do it anymore. This condition is not so common as a bad cell, but it does happen, it did to me.
I hope this helps.
I have a Poulan Pro Trimmer. I don't think its getting fuel. It won't start for nothing. Can you tell me about the carburator, or some other problem? Thank you. I also need a new owner's...
http://www.poulanpro.com/node7962.aspx
GO TO THE ABOVE ADDRESS YOU WILL FIND WHAT YOU ARE LOOKING FOR.
REGARDS.
PLZ. DON'T FORGET TO RATE
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
