Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Bin bottom release snapped off. How do i open the bottom?
The bottom of my cyclone bin will not open as the release catch has snapped off and i cannot work out how to take the bin off! any ideas???
  • 43 Answers
Take out the three screws on the to near the handle inside you will find the remains of the old part you can either replace the old part from the top and put it back together to open it normally or you can use the old release stick to push down the catch at the bottom if you decide to replace the part make sure the release stick is in the centre through the 2 holes its very tricky
Posted on Nov 11, 2008
The shroud on my dc59 is full of dust is there any way of cleaning it
Hi Marian, it's Jack at Dyson.
It's normal for harmless static to cause fine dust particles to cling to parts of the cyclone pack after use. This won't affect performance as the airflow doesn't need to pass through this dust.
It's not possible to remove the mesh shroud, but you can clear any fluff or clinging debris from the shroud after removing the clear bin. In order to do this, press the red bin base release catch once to open the bin base. Then with the base still open, press the same red release catch firmly a second time to disengage the bin.
You can then use a dry cloth or soft brush to remove any debris from the fine mesh shroud. Please don't attempt to wash or submerge either the clear bin or the cyclone pack, as this could cause damage not covered under your Dyson warranty.
I hope this information is useful, but you're welcome to get in touch with our experts if you'd like further guidance. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jan 06, 2015 | Dyson Dc50 Ball Multi-Floor 2-Tier...
The dust collecter is stuck and won't release from the vaccum. how do i release it to empty.
Make sure you switch off the vacuum cleaner.
Here is the instruction to remove the bin
Press the cyclone release catch with your thumb to remove the
clear binTM assembly from the machine.
• When removing bin, do not pull up on carry handle while pressing cyclone release catch
• When replacing the bin, ensure it clicks back into place.
Dec 31, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I remove canister to clean dyson Dc24
Hi there, it's Jack at Dyson.
To remove DC24's clear bin from the cyclone pack, first remove the clear bin and cyclone from the vacuum, and press the red bin base release trigger to open the bin base - as if you were emptying the machine. Then with the bin base still open, look at the rear of the cyclone pack for a silver catch - this catch will allow you to disengage the clear bin.
With the clear bin removed, you can use a soft brush or a dry cloth to remove any debris from the perforated shroud. Please note, the cyclone pack should never be washed or submerged in water as this can cause damage to your machine not covered under guarantee.
I hope this helps, but if you'd like any further advice on using or maintaining your DC24, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 12, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Cant get the bottom lid of dyson dc7 dirt bin to open
I am sorry to hear you are having difficulty opening your clear bin. The mechanism that releases the bin base is actually part of your cyclone assembly. When you pull the trigger, a small clip at the bottom of your cyclone releases the bin base. If this clip is missing or broken, part replacement may be needed to resolve the issue.
You can call us directly to order the the cyclone assembly at 0800 298 0298 (UK) or 1-866-693-9766 (US). The part is also available on our website.
Best wishes,
Jessica
Nov 24, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson canister won't fit snugly
I am sorry to hear your canister is not fitting properly. You may want to separate your cyclone assembly (the top purple portion of your canister) from the clear bin and reattach the components to ensure they are fitted together properly.
To do this, open the bottom of the clear bin, as if you were emptying it. Please be sure the bin is positioned over a trash receptacle in the event there is debris in the bin. Once the bottom of the bin is open please look at the back of your canister. Below the purple top of the canister and to the left of the debris inlet is a clear plastic loop that you can slip your index finger through. Just above this loop is a gray release catch . Using your thumb, press down on the gray release mechanism. At this point you should be able to gently pull the clear bin away from the cyclone assembly. After separating the pieces, briefly inspect them to confirm they are not damaged. If there is no obvious damage, close the base of the clear bin and place the bin on a hard flat surface. Next, carefully lower the cyclone assembly onto the clear bin. It may be helpful to use the red plastic piece on the back of your cyclone assembly and clear bin to line the pieces up correctly. You will hear a slight click once the pieces have been successfully reattached.
Please attempt to return the canister to the machine. If you are still not able to attach the canister successfully, please call us so we can provide further assistance. We can be reached at 1-866-693-9766 (US), 0800 298 0298 (UK), and 01-475-7109 (IE).
Best wishes,
Jessica
Jun 22, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
How ldo I open the Dyson DC07 bin to clean the mess out
Empty the bin in the usual way. Leaving the bottom door open, raise the small catch on the front of the bin, towards the top. Pull the front of the bin down when this catch is held open and the clear bin will disengage from the top lug at the back. The whole clear outer bin them can be removed dowards to enable the cyclonic air wholes to be totally cleaned.
This is for the DC07 all floors but I asume all DC07s to be the same.
John
Aug 02, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a dyson dc07 bagless vacuum cleaner. How do I split the top and bottom halves of the dust collection bin? There is a lever and catch on the side, I have tried pulling and turning, but with no...
Hi at the top of the Cyclone there is a lever underneath the Handle. The Handle I am referring to says Dyson on it. Firstly you must release the Cyclone from the spine. After doing this you will be left with the Cyclone and the Cyclone Bin all in a oner.
To empty the bin you must lift the lever which is underneath the Dyson handle.
You can only seperate the bin from the cyclone whilst the bin flap is open.
Once you have opened the bin flap using the lever you can then use the lever and catch to seperate the 2 items.
Oct 25, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Clear Bin Flap will not release
I just received my replacement root cyclone in the mail today after waiting in the back-ordered status for three months. I positioned a butter knife in between the rubber gasket on the bottom flap lid and the bottom rim of the clear bin at the farthest point from the hinge and slowly and gently wiggled the knife between until the bottom flap just fell open. I examined the rubber gasket and it survived without injury and the bottom flap seals without any gaps...good luck
Jun 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Fitting internal bin catch on dco7
Yea I can definitely help you. On the tope of the cyclone there are three screws that will allow you to take off the top off the cyclone. You should see a long black rod going down the middle of the cylcone. It is difficult and you may have to detach it from the top i cant remember as usually i just replace the whole thing and only done that 3 times. You take a flash light and you can see where the rod goes in and just push it down and it should pop open. ill check back on monday to see if you replied or need more help.
Dec 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bottom of dirt container doesn't stay closed
The catch/latch that is on the bottom of the bin button release has likely broken.
If you take out the canister (as when you are dumping the bin), and flip it upside down and then squeeze the bin release button, you will see that it moves a rod inside the cyclone assembly.  At the end of this rod is a plastic (plastic.. redundant, as the entire Dyson is practically plastic) latch that catches onto the bin's lid and locks it in place.  A broken latch means it doesn't lock the lid in.
What you need is a replacement latch.  Note that the "Bin Release Button + Rod assembly" that are sometimes sold on ebay do *not* contain the latch at the end of the rod.  Also the bottom bin assembly does not contain the required parts.
The cyclone assembly should have the full bin release rod + latch, so if you can't find the latch, then a new cyclone assembly would work also (but will cost more, obviously).
Oct 09, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
235 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
