Question about Corona 23-DK Compact Heater
Wick how do i change the wick gor a corona d23
  • ladylee74 Nov 09, 2008
    someone please tell me how to change the wick
    Problem Solver:
I must warn you, replacing the wick is a very tricky job. You should take it to the place where you buy the wick and let them install it.  Call first to make sure they provide this service.
Posted on Nov 10, 2008
How do I replace the wick on a corona 23. I lost my manual
If you've already purchased a new wick from a reputable dealer/retailer and its the one designated for your model Corona heater. The installation instructions come packaged with the wick. I would encourage you to wear rubber gloves if the heater tank still has kerosene in it.
Feb 01, 2011 | Heating & Cooling
I have a 23-dk corona kerosene heater. it was smoking so i replaced the wick. after replacing the wick it still smokes heavy. how do i fix the problem.
Check all airvents into conbustion chamber. Make shure they are all clear of blockage. The heater needs air to burn fule properly. Check wick adjustment it may have to much wick.
Sep 03, 2010 | Corona 23-DK Compact Heater
Changed wick in corona 23dk , now has very high flame and smokes like crazy.
the wick is round in this heater and may have to be cut for height. should be about an eigth of an inch below the top
Jan 11, 2010 | Corona 23-DK Compact Heater
Aladdin tr 5000 how to change wick
You have to take the heater apart, in order to change the wick out. be sure to wait an hour before lighting the heater afterwards. That is necessary, and should be heeded.
Dec 29, 2009 | Corona 23-DK Compact Heater
Have a Dyna-Glo. Took it apart to change the wick
take the wick back out lower your nob and install wick, I hope this help you, I have made this mistake too
Oct 23, 2009 | Corona 23-DK Compact Heater
Corona 17 dk
Just pull it out with pliers. It has sharp directional tabs pointing down holding it in. Once the wick is pulled out, it is no good. New wick pushes right in.
Apr 03, 2009 | Corona 23-DK Compact Heater
Change wick corona dkc22
u need to start at top . remove cage from top. there should be a few screws on the side of the upper case (the round upper part of the heater) once that is removed u will see the shaft the wick is attached to,the heater control are mounted here too. there should be some screws or wing nuts remove them. now lift the shaft out the wick will come with it (carefull wick wiill be wet with kerosene) remove old wick. when replacing new wick make sure to allign the top of the colored band with the top of the wick holder(the piece with the pins that adjusts the wick up & down) lower shaft & wick back onto heater and reasemble heater .be sure all controls and shut off work smoothly and correctly.
Jan 10, 2009 | Corona 23-DK Compact Heater
Corona DK 23 kerosene heater won't start
try bringing your wick up to the fully raised position and pinch and bend the wick toward the igniter until they line up right. I have two coronas one of which has a broken igniter due to wear and tear. If you open the little door,press down the start lever,and light the wick with a barbecue grill lighter,you can safely light the heater if lining up the wick fails.
Oct 09, 2008 | Corona 23-DK Compact Heater
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Corona 23-DK Compact Heater Logo
188 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
