DOES NOT POWER UP
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure the CPU central processing unit has thermal grease and a dust free secure seating even something as small as an electrical extension or a faulty fan lead can cause this problem computers need all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge some motherboards cmos batteries are soldered in
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
hope it helps
