There is a black line acroos the page on all copies from a Canon PC745 copier
  • 2 more comments
  • Bobrcr Nov 09, 2008
    The line is 5/10" wide and 11' across the page. It is light enough so that you can still read the print under the line. I have removed and reinstalled the cartridge which is almost brand new. Please advise details of any special cleaning if appropriate.
    This is a copier not a printer. It cannot be connected to a PC
    What chemical should be used to clean the optical mirror?
    Where is the optical mirror?
    The question about where the optical mirror is located has not been answered. I have over 30 years experience in working on copiers, all of them much larger than this one.
  • 1,879 Answers
The mirror is inside the copier and obviously you have to open it.
Lens and Mirrors: These are the components of the conventional analog copier that convey the scanned image from the glass to the photoconductor drum. The mirrors direct the light through the lens (for focusing or magnification) to the drum.
Tada! it's near the drum.
Posted on Nov 09, 2008
  • 728 Answers
Try printing a test page to align and clean the printer cartridges and if it is still there, try un-installing and re-installing the software that came with the printer. To print a test page, go to control panel, go to printers and faxes, find your printer on the list, right click on it and go to properties, and on that list go all the way down to the bottom page and click print test page.
To un-install the software, go to control panel, go to add or remove programs, find your printing program on the list and select remove, and after removing, restart your computer and put the software back on. It should work then.
    Scholar:
  • 112 Answers
There is something not properly lined up. Make sure the cartrige is inserted correctly. You could contact cannon and see what they say. I really need more info such as size, location, and qualities of the line.
    President:
  • 2,712 Answers
Is it always in the same position on the paper, or does it vary?
  • 2 more comments
  • Swilin Sampson
    Swilin Sampson Nov 09, 2008
    You could try cleaning the optical mirror, rollers and fuser roller first..
  • Swilin Sampson
    It could also be that there is a fault with the drum unit which will have to be replaced. This usually happens on units that have more than 50,000 copies made. The drum could have a dent, etc where the toner gets stuck and produces the streaks. If the streaks occur more or less in the same area on every page, then this is most likely the issue.
    This will require a replacement of the drum, for which a service call will be required.
  • Swilin Sampson
    @ jazzboy : THIS IS NOT A PRINTER.
  • Swilin Sampson
    Best would be to use isopropyl alcohol on a cotton swab. Dont saturate it though! However, if you are not familiar with opening up copiers, I wouldn't recommend this.
    In all likelihood, its the drum unit and will have to be replaced..
Black lines across the page after several clear copies
if the lines are acroo the page width then measure the spacing.
If its regular then its due to contmination somewhere in the paper feed. Can't help more without knowing the make and model of printer. Is it thermal,.laser, LED or inkjet?
Mar 14, 2015 | Office Equipment & Supplies
Canon PC745: When I make copies they come out dirty on one side of the paper. I replaced a toner cartridge, cleaned with air duster. Did not help.
You need to clean ALL the mirrors in the optics of the machine. Including the really hard to get at mirror in the middle underside.
Feb 26, 2011 | Canon Office Equipment & Supplies
Horizontal streak
Clean the scanner strip glass. This is the small strip of glass that is just to the left of the large main glass. This is the only cause for black line (s) when copying using the ADF(top feed). If prints or copies fine from the glass then it is this strip glass needing to be cleaned.
May 04, 2010 | Ricoh Aficio 450 Copier
Orange warning symbol on my Canon PC745.
have a look for a piece of paper stuck over a sensor or a sensor flag broken or stuck, thats why it still thinks it has a paper jam in it
Sep 27, 2009 | Canon imageRUNNER 5000 Copier
PC745 error code - what is it. Source for manual?
that is the symbol for a paper jam. the figure 8 represents the rollers and the zig zag is the crumpled paper.
Dec 27, 2008 | Canon PC-940 Black and White Copier
Canon PC745-Spring has fallen off...
The plastic hook it goes to is problay broke. Looking at the back of machine it should hook towards the left find something close to hook it to. I've done this and haven't had any problems since.
Aug 31, 2008 | Office Equipment & Supplies
White line and very, very dirty copies
the nealy black copies sounds like the drum is going, try adjusting the exposure to light, if it comes out with the whole page the same way but just lighter than change drum. White line sounds like there is something on the coronas.
Jul 22, 2008 | Canon PC-940 Black and White Copier
BLACK LINE ACROSS THE COPY CANON IMAGE 2200
Most likely your drum unit is worn out. If it reaches the yield of 50k or more, it starts to develop grooves in the drum and toner gets stuck in the groove and is applied to your pages. If you have a service company, they can change it for you. We sell the drum for $220.
Jun 30, 2008 | Canon imageRUNNER 2200
jasbo
jasbo
