Question about Canon i860 InkJet Photo Printer
I860 power supply apparently bad
My i860 quit working in the middle of a job. It shut off and won't restart. I took out the power supply and measured voltage. Information on the piece says it should be putting out 24 volts. Mine was doing 7 volts. I can't find a replacement power supply, and it's not worth taking to a repair center. Are there any other options?
  • Jimmy Parsons Nov 09, 2006
    Two weeks later, I've had no solution other than try to find a new power adapter. They must be rare (except at a high price), but a friend has one on the way.
  • Anonymous Dec 08, 2007
    1. I have the same problem : printer just stopped working; does not even turn on. I brought it to a repair person who suggested I get a new power supply. But I have no idea who has them.
Same problem here, 7 & 14 volts instead of 24 & 27...  No luck finding one either, except for one in germany on ebay that doesn't ship overseas.
Posted on Aug 27, 2008
Tip
Dell vostros 220 cd/dvd drive not working
my cd/dvd drive quit working device manager showed the triangle and ! mark, properties showed code 10. shut power off, took side case off, unpluged both cd/dvd's, from the board, restarted machine let it reboot, shut power off again,plugged both cd/dvd's back in, restarted machine, both were reinstalled and now working. hopes this is some help to somebody else. thanks jim.
on Jun 22, 2011 | Dell Vostro 220 Desktop Computer
My computer keeps shutting down for no apparent reason... I hasve a toshiba satellite p10...
Possible causes of the problem:
System overheating
- Virus infection
- Power supply malfunctioning
Solutions:
- Check your computer if the fan is properly working.
- Scan your computer for viruses
- Check your computer power supply by a qualified technician
- Reinstall your computer operating system
Try this also:
From the run box you can type shutdown -a and that should stop it from shutting down long enough for you to fix the problem.You need to look up how to remove msblast from your computer.
Nov 17, 2009 | Toshiba Satellite P105-S921 Notebook
I took my gateway gt5620 in because it would shut down by itself. It would restart. They took the graphics card out and it worked for a while. Now it is doing the shut down again. I took the side panel off...
Sounds like an overheating problem. May want to remove the processor and check the heat sink material. While you have it out you can clean the fan and the heat sink. Make sure your air flow isnt blocked in any way and neaten up the cables if necessary. You could also consider adding another fan.
Oct 01, 2009 | Gateway GM5620 PC Desktop
Computer shuts down
most pcs will shut down to protect themselves in some way. need a bit more info, age, make etc
Jan 11, 2009 | Computers & Internet
Computer shuts down
Could be the power supply,Try changing the power supply
Jul 12, 2008 | Computers & Internet
Dell E173FP 17" LCD goes black after 2 or 3 seconds
My solution: I searched many posts. My LCD also went black after 10 minutes or so, and green led was still on. Then i had to press power off and on to display again for minute or 2. I used reset function in its osd. And problem is gone! Yai!
Mar 27, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Power supply
you are so lost... a short in anything after the power supply will shut down the horizontal driver signal. first check to see if horizontal output transitor is shorted. If not it should have about 110 volts dc on it. if not go back to Power suppy ...many things start here...check to see if you micros got power a 5v heatseeked regulater is common bad. also the startup circuits can be tricky...in the power suppy. I look for a kit online for power supplies ...they give you about every that fails. or you can start buying boards...best bet it is take to a professonal for you my freind havent a clue. CrazyLarry
Jun 27, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Canon i860 InkJet Photo Printer Logo
289 people viewed this question
old marine
old marine
